I've a OLED screen 1.3" with the SH1106 driver.
I've seen your gLCD_SSD1306_i2c.fcpx, i think you can make an SSD1106 ( SH1106 ) for FC V6.
In some forums, there is a modification to do that :
On file : u8g_dev_ssd1306_128x64.c
Find line 183:
Code:
0x000, /* set lower 4 bit of the col adr to 4 */
Change this to
Code:
0x002, /* set lower 4 bit of the col adr to 4 */
I can't modifie gLCD_SSD1306_i2c.fcpx, perhaps you can make an I2C and SPI component ?
Thanks in advance
OLED 128x64 with SH1106
Forum rules
Re: OLED 128x64 with SH1106
Here is the source for the SSD1306 I2C component. You should be able to make the changes you need, change the component GUID and create yourself a new component.
If you get anywhere with it then you can share the component and we will put it into the build.
Some help on creating components is available from the Component Creation section of this page: http://www.flowcode.co.uk/wiki/index.php ... p_Overview
This page specifically has some good videos to help get you started: http://www.flowcode.co.uk/wiki/index.php ... a_Property
Hello BenJ,
I've read the source code and the modification to do is :
I think that i can modifie the source at SendData(pixel_width - 1) to SendData(pixel_width +1)
Can you confirm it to me ?
thanks
source : http://forum.arduino.cc/index.php?topic=256374.0There is only one small difference between SSD1306 and SH1106: The SH1106 controller has an internal RAM of 132x64 pixel. The SSD1306 only has 128x64 pixel.
First problem for standard 128x64 OLEDs with SH1106 controller is: How is the 128x64 window mapped into the 132x64 RAM?
It seems, that the 128x64 OLED is centered in most cases within the 132x64 area, that means pixel (2,0) in ram is pixel (0,0) on the display.
thanks
That sounds right to me
Hello BenJ,
I've tested your 1306_i2c code and the oled screen work very slow.
With adafruit test file, it work without "lag"
any idea ?
thanks
any idea ?
thanks
OK, so, my project is for an arduino nano.
I changed this file "AVR_CAL_I2C.c"
and i put #define MX_I2C_DELAY delay_us(1);
in line 75
Now the screen work faster but i can't make a scroll fonction....
to Benj : My Oled SSH1106 in I2C mode wont work. I'll try a with the SPI.
thanks for your help.
Do you have any positive results with the OLED SH1106 and I2C?
What OLED type do you use?
How about SPI? How did you connect it? Do you use Arduino or another microcontroller?
I use PIC18F4550. If it is working for you, could you share the code or component for SPI and I2C? Or maybe some photos, diagrams with connections?
Below is a link to a new set of questions related with OLED SH1106:
http://www.flowcode.co.uk/mmforums/viewt ... 509#p68509
