Pin configuration change after save/close/open
Has thanked: 182 times
Been thanked: 179 times
If I configurate the UART with the corect Pin for RX = F2 and TX= F8. After save and close/open again, the Pin for RX/TX change to A14/A15.
Thats confusing....
And I dont understand why RX/TX remable is showing
(19.78 KiB) Downloaded 1021 times
(18.2 KiB) Downloaded 1021 times
Flowcode_test_2018_sdcard1.fcfx
(45.03 KiB) Downloaded 293 times
Re: Pin configuration change after save/close/open
Hello Stefan,
Many thanks for letting us know.
I've had a bit of a go with the component and now think that I've solved the problem for you.
Simply copy the attached into your "Flowcode 7/Components" directory and restart Flowcode.
RS232.fcpx
(14.96 KiB) Downloaded 276 times
Let us know how you get on.
Perfect. it's ok now.
Another idea of the serialport....
Can you support in the selector
230400Bd
460800Bd
921600Bd
And can you include in the software uart a very simple IRQ like in the hardware uart?
