Last week I did the upgrade from FC 6.1.0 to 6.1.1
Since then, I have had a problem in that any programme I down load to the micro hardware (e.g. EB006) now reads an analogue input of up to 5 volts with the wrong value, for instance I only get a read value of 128 for 5volts measured input. I have checked this by using the same programme on the same hardware but flashed using a different computer and different licence (FC 6.1.0). Ive cross checked all the relevant settings and they seem to be identical on both machines (programme attached
Please help, is there a setting Im not aware of? or do I need to revert to 6.1.0? If so how?
Chris
Bad installation of FC6?
Chris_MIRA
- Has thanked: 2 times
- Been thanked: 21 times
Chris_MIRA
Re: Bad installation of FC6?
Forgot to add in the original message, values etc work okay in simulation but using ghost gives the hardware readings which are the faulty ones...
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Hi Chris,
Looks like a recent fix for 16F726 has broken 16F1937
Please try the attached CAL file (into Flowcode\CAL\PIC)
Leigh
Leigh
- PIC_CAL_ADC.c
- (97.74 KiB) Downloaded 252 times
Chris_MIRA
