Component: Magnetometer (BMM150) (Environmental)
(Redirected from Component: ID 36175036 08af 4bcf 8dd2 1c46f6761385)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Environmental |
Magnetometer (BMM150) component
A low-power, low-noise 3-axis digital geomagnetic sensor that perfectly matches the requirements of compass applications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_BMM150.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_BMM150.fcfx
Initialise | |
Startup communications to the sensor module. Puts the device into normal operating and preset modes. Returns 1 if module found and communicating. | |
- BYTE | Return |
ReadRegister
ReadRegister | |
A simple example showing a generic way to read a register using I2C. | |
- BYTE | Address |
- BYTE | Return |
ReadSample
ReadSample | |
Collect a sample fromt he last SampleMag operation | |
- BYTE | Axis |
0=X, 1=Y, 2=Z | |
- INT | Return |
SampleMagData
SampleMagData | |
Samples the magnetometer and processes the data ready to be read out using the read sample macro. | |
- BOOL | ApplyTrim |
0=ReadRawValues, 1=ApplyCalibrationTrim | |
- VOID | Return |
SetOperatingMode
SetOperatingMode | |
Select the operating mode and power level used by the device | |
- BYTE | Mode |
0=Normal, 1=Forced, 3=Sleep, 4=Suspend | |
- VOID | Return |
SetPresetMode
SetPresetMode | |
Controls the device sample rate and accuracy | |
- BYTE | Mode |
0=LowPower, 1=Normal, 2=HighAccuracy, 3=Enhanced | |
- VOID | Return |
WriteRegister
WriteRegister | |
A simple example showing a generic way to write a register using I2C. | |
- BYTE | Address |
- BYTE | Data |
- VOID | Return |
