Hello everyone,
I would like to use the HX711 and for that I took the flowchart which is given in the help.
I am using a PIC 18F26K22 and under Proteus it does not work.
Has anyone ever encountered this problem?
I have tried several modifications but the result is always the same.
Thank you in advance for your feedback
HX711 Do not work
- Been thanked: 5 times
- Has thanked: 509 times
- Been thanked: 472 times
Re: HX711 Do not work
Hi.
A post in Dec 2021 states HX711 works on PIC32.
Although It's not the same family as 18F26K22 so there may or may not be an issue?
I would recommend trying on real hardware first, to eliminate possible bugs with proteus.
If it does not work on hardware, then we can take it from there.
- Has thanked: 438 times
- Been thanked: 602 times
We use the HX711 device on a lot of our in house hardware so I'm very surprised you're having problems.
I've have a look at your program and it looks ok so I think I agree with Martins view to try on some real hardware. It could be the proteus sim is somehow flawed or incompatible.
As a test you could try disabling the SetSampleCount and SetScaling macro calls to try a really simplified version just in case these are causing the problem.
Thank you very much for your answers.
I tried disabling the two macros and it is the same.
To try in real hardware, I have to wait to receive the components I ordered.
When I receive them I will be sure to keep you informed.
Thanks again for your answers
Luc
Luc
Hi Martins and Ben,
good news I received the HX711 and it works in real.
I now have to work on the program to improve all that.
Many thanks again for your support
Luc
Luc
- HX711_Example2.fcfx
- (12.52 KiB) Downloaded 89 times
