Page 3 of 3
Re: Automatic Com port Select
Posted: Tue Jun 29, 2021 4:35 pm
by stefan.erni
Hi Oscar, Hi Ben, Hi Steve
On my board (a mobile recorder).I have a bluetooth module
microchip RN4677-V/RM100.
This works very well with Flowcode. Fortunately, the automatic detection also works nice.
But I have connected several recorders to my computer. These have the same "_VID & 00010039_PID & 5050"
Can I somehow differentiate them with the bluetooth name? The bluetooth name is unique.
- Comport_2021-06-29_17-28-09.png (16.2 KiB) Viewed 6562 times
Posted: Tue Jun 29, 2021 4:54 pm
by Steve-Matrix
Hi Stefan,
I'm about to finish for the day (there's a certain football match about to start
), so I will look into this tomorrow.
Posted: Wed Jun 30, 2021 10:17 am
by Steve-Matrix
Hi Stefan,
Sorry, I've spent a while looking into it this morning without success. Without the hardware, it is difficult for me to see where the information is stored within Windows.
What is listed in the COM port dropdown in Ben's example program when these devices are connected?
Posted: Fri Jul 02, 2021 11:15 am
by stefan.erni
Hi Steve
For now I removed all recorders, except one recorder.
For one Bt modull the computer shows always 2 comport.
So the program from Ben found the recorder, choosed the correct comport (com4) and not the wrong comport (com3) from the BT device.
and started recording and stoped the recording after 10 seconds.
So with one recorder perfect!
In the dropdown menue is this.. If it's posible to show more info in the dropdown panel, like the VID PID will also help to choose from hand.
PS. You dont need to rush, I also watch the swiss team this evening
- auto_2021-07-02_11-54-46.png (16.84 KiB) Viewed 6537 times
Posted: Fri Jul 02, 2021 11:53 am
by Steve-Matrix
We could add the VID/PID to the list, but I think for your BT module this will show the same VID/PID for the 2 COM ports associated with it. And if you had multiple modules of the same product connected, these would also show the same VID/PID.
I've looked into this and I think Windows stores COM port info in a complex way. It depends on the type of COM port. For example, my PC identifies 2 COM port entries in the registry (Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\COM Name Arbiter\Devices) - one under "ACPI" and one under "USB". More details of these can be found by finding each entry in "Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum".
If you have a look at these areas of your registry and find a way of differentiating them for your needs, then I might be able to find a way of exposing this information in Flowcode.
Otherwise you may need to find another way of achieving what you want.
For example, we have a Bluetooth product - our Formula AllCode robot buggy. When more than one of these are connected to the same PC, the only way for us to differentiate them is to open each COM port and ask it for it's name.
Posted: Fri Jul 02, 2021 2:11 pm
by stefan.erni
Hi Steve
From all my Modul i now the Bluetooth_uniqueID .
From this modul is 801F12B866AC. From this I generate the BT name EMG-66AC (the BT modul has a command to creat the name with a string and the last 4 numbers of the ID)
How can I read the Bluetooth_uniqueID in the computer?
I tried with getprop, but it's not working.I did something wrong
- Decice_2021-07-02_15-04-02.png (5.34 KiB) Viewed 6531 times
- Bluetooth_2021-07-02_14-50-50.png (117.98 KiB) Viewed 6531 times
- id_2021-07-02_14-53-19.png (132.22 KiB) Viewed 6531 times
Posted: Fri Oct 01, 2021 2:41 pm
by stefan.erni
Hi to All
Atomatic Com Port Select is a good idea and working fine if you know the VID and PID
As a sample for the Microchip Bluetooth Modul RN4677 the HWID is working with "_VID&00010039_PID&5050"
But what is the HWID for the ESP32? I can not found a VID or PID
Posted: Fri Oct 01, 2021 4:58 pm
by Steve-Matrix
I think you can find the vid/pid of a device attached to a PC using Windows Device Manager. Find the device in the list and then right click and select "properties". In the details tab there should be a "Hardware ID" entry.
