Why this..Options have been disabled due to restricted license?
Posted: Wed Oct 13, 2021 4:21 pm
I have been having problems using both the Flowcode 6 & 7, which I have licenses for them. I uninstalled and reinstalled Flowcode 7 to see if this would resolve the issue. It did not.
I noticed in the compilation phase of the project that the following message was provided, "Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key." I am using a PIC24FJ chip. I have licenses for the PIC8, PIC16, PIC32, among others.
I believe last year was the last time I used the program prior to porting over to Win10. When I used it last, everything was fine. Any idea why the error message is there and how I resolve it?
Here is the compilers output:
D:\FLOWCO~2\CHEMIC~1\RS232T~1>xc16-gcc -c -mcpu="24FJ64GB002" -omf=coff -funsigned-char -fno-short-double -Os -I"D:\PROGRA~1\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"D:\PROGRA~1\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "RS232_PIC24FJ64GB002".c -o "RS232_PIC24FJ64GB002".o
RS232_PIC24FJ64GB002.c: In function 'FCM_RS232_Request_Unknown':
RS232_PIC24FJ64GB002.c:754:2: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
D:\Program Files\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:899:13: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
RS232_PIC24FJ64GB002.c:758:2: warning: passing argument 1 of 'FCD_047b1_RS232__SendString' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c:588:6: note: expected 'MX_CHAR *' but argument is of type 'volatile MX_CHAR *'
RS232_PIC24FJ64GB002.c: In function 'FCM_OSCILLATOR_Initialize':
RS232_PIC24FJ64GB002.c:795:6: warning: large integer implicitly truncated to unsigned type
RS232_PIC24FJ64GB002.c: In function 'FCM_RS232_Request_3':
RS232_PIC24FJ64GB002.c:883:2: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c:887:2: warning: passing argument 1 of 'FCD_047b1_RS232__SendString' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c: In function 'FCM_RS232_Request_2':
RS232_PIC24FJ64GB002.c:976:2: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c:980:2: warning: passing argument 1 of 'FCD_047b1_RS232__SendString' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c: In function 'FCM_RS232_Request_1':
RS232_PIC24FJ64GB002.c2: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c2: warning: passing argument 1 of 'FCD_047b1_RS232__SendString' discards qualifiers from pointer target type
RS232_PIC24FJ64GB002.c: In function '_U1RXInterrupt':
coff-cc1.exe: warning: _U1RXInterrupt PSV model not specified for '_U1RXInterrupt';
assuming 'auto_psv' this may affect latency
RS232_PIC24FJ64GB002.c: At top level:
RS232_PIC24FJ64GB002.c2: warning: '_CONFIG4' definition has been deprecated: consider migrating to #pragma config
RS232_PIC24FJ64GB002.c2: warning: '_CONFIG3' definition has been deprecated: consider migrating to #pragma config
RS232_PIC24FJ64GB002.c2: warning: '_CONFIG2' definition has been deprecated: consider migrating to #pragma config
RS232_PIC24FJ64GB002.c2: warning: '_CONFIG1' definition has been deprecated: consider migrating to #pragma config
Compilation successful!
Completed compilation, return = 0
Thank you
Thank you
