App Developer How to open a Browser Page
Has thanked: 149 times
Been thanked: 171 times
In C# it's easy to start the IE explorer and open a page just with pressing a button
Is there a way to to this in the App Developer?
       private void button2_Click(object sender, EventArgs e)
            string target = "https://www.flowcodexchange.com/";
            try
                System.Diagnostics.Process.Start(target);
            catch (System.ComponentModel.Win32Exception noBrowser)
                if (noBrowser.ErrorCode == -2147467259)
                    MessageBox.Show(noBrowser.Message);
            catch (System.Exception other)
                MessageBox.Show(other.Message);
Has thanked: 167 times
Been thanked: 277 times
Re: App Developer How to open a Browser Page
Hi Stefan,
I don't know any simple way of doing this in Flowcode, but I might be able to add a new Build-in Function.
That said, Ben might know a way...
Hi Steve
like a little hint
The Datarecorder has a button " ? "
If I press it, in the running app,
it's open the IE explorer with the wiki from flowcode.
A button that I can choose the page...
Has thanked: 438 times
Been thanked: 602 times
Hi Stefan,
Just a thought but can your C# code be put into a DLL. If it can then Flowcode can call DLL functions.
https://www.matrixtsl.com/blog/expandin ... sing-dlls/
Ok I saw how it's works.
I think I can do something like the test function.
	//Test Function
	DECLDIR unsigned char Add( unsigned char a, unsigned char b )
		return (a+b);
	/Open Explorer Function from Stefan
	DECLDIR OpenWebsite (char * cpURL)
                 ShellExecute (NULL, "open", cpURL, NULL, NULL, SW_SHOWNORMAL);
		//OpenIEE Function
	DECLDIR unsigned OpenIEE( String a)
		return ;
But your sample for the DLL is already old. It's for Visualstudio 2008.
If I open it with VS2019 I get some errors.
I will have look about it
There is second wish
How to start a batch file from App Developper?
If I put this text in a batchfile it's starts the page in the IE
start msedge https://www.flowcodexchange.com/
Time-Date-String.zip
(7.14 KiB) Downloaded 155 times
This one was done a lot more recently, hopefully shoud give you more joy.
Keyboard.zip
(26.33 KiB) Downloaded 181 times
Yes. Thanks a lot.
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
I saw the the sample ReadDate.fcm is also old and FC8 has the dll on a different place.
Is it possible to have the keyboard.fcm from FC9 ?
Hi Stefan,
Here you go.
GetKeyPress:DLLs[$(appdir)API.DLL\Keyboard.dll]
If you look at te Build -> Compiler Options window then you can see all the useful directories available and their variable name.
e.g.
$(appdir) or $(srcdir)
I changed the keyboard dll. When I press the a key, it becomes retval 10 and starts the explorer with the desired page. It's working!
well I have to see how I can make more meaningful
     #include <shellapi.h>
     DECLDIR unsigned char GetKeyPress(unsigned char key)
        unsigned int ret;
        unsigned char retval = 0;
        ret = GetAsyncKeyState(key);
        if (ret & 0x0001)
            retval = 10;
        if (ret & 0x8000)
            retval = 10;
        if (retval==10)
            ShellExecute(0, 0, L"https://www.flowcodexchange.com/", 0, 0, SW_SHOW);
            return retval;
