Please can you post your program and we will investigate for you.
I've looked at DMA for the DAC and it looks possible, however you have to do it via the I2S DMA and we already know this has a problem at the moment. It's on our road map to fix this and get this working nicely so we will try and add DAC DMA support at the same time.
Esp32 Timer Problem
- Has thanked: 435 times
- Been thanked: 598 times
Re: Esp32 Timer Problem
- Has thanked: 69 times
- Been thanked: 208 times
The ESP32 debug monitor might help.
To run it ...
Attach the ESP board to your PC USB.
Determine the COM port that is uses (see Device Manager)
Run the ESP-IDF Command prompt (should be on your PC desktop)
cd to your Flowcode project directory
type and run: idf.py -p COMx monitor
where COMx is your COM port e.g. COM10
You should then see debug output from the ESP board that should help you
To run it ...
- Has thanked: 37 times
- Been thanked: 10 times
Thanks Leigh
i got confused with com ports. I keep the programming com port open with another program and this created the problem.
Once all the programs that used the com ports were closed everything was back to normal
I'm sampling a signal with the adc port and sending the sampled signal as a float via uart. I also want to save the same value inside the esp32. (this way I can recover it if I have a problem with the pc)
I tried to use the lut table but without success..It appears that no new values are added to the lut and it always remains blank
Hi Leigh
Yes, I have now implemented a circular buffer and everything works.
Is there a way to save data in esp32 (type eeprom) or do I have to use an external memory chip?
It looks like you can use the ESP32 flash memory like EEPROM, I've found a library that does this so I'll have a go at porting this into Flowcode so you can do this using the EEPROM component.
I've added some basic EEPROM functionality now to the ESP range of devices using the EEPROM component. Please note that the initial values property doesn't currently work and so I advise to keep this blank until if/when we can get this working too.
I've tested it and it seems to work well but let us know how you get on.
At the moment you can store 16-bit numbers, however there is scope to be able to store much more so let us know what else you would like to see.
Great! Thank you.BenR wrote: ↑Wed May 26, 2021 12:18 pmHello,
I want to store a Float but these are 32bits.
Is there a way to do this with current component? There is a "WriteFloat" macro for the EEPROM in the making?
You can use the type conversion component to take a float and then get two 16-bit or four 8-bit binary values which you can store into the EEPROM.
To pull back out from the EEPROM do the oppsite, load the binary values and then pass back through the type conversion component to regain your float value.
