STM32 I2C master BUG
Posted: Thu Jul 15, 2021 11:49 am
by Oscar_T
With i2c master version 5 I can't compile my program
The compiler reports this message to me
"Errors when generating C source code:
Mainboard_013.c : 1 : error : Unknown or missing component: I2C_Master1::SendByteTransaction
Mainboard_013.c : 4359 : error : Unknown or missing component: I2C_Master1::SendByteTransaction
Autoclose turned off
If I use version 4 everything is ok
Kind regards
Kind Regards
Re: STM32 I2C master BUG
Posted: Thu Jul 15, 2021 12:25 pm
Hi, Oscar.
It looks the component has had the name of function SendByteTransaction changed to GenericWriteRegister.
If you would like to post your flowchart, or pm if you want to keep it private, I can sort it out for you.
If you want to manually change it yourself, then I can help you with that.
Posted: Thu Jul 15, 2021 4:06 pm
by Oscar_T
Hi Medelec
Thanks for the advice
I changed all SendByteTransaction with GenericWriteRegister. It compiles correctly but it doesn't work ...
Has something else changed or is it just a rename?
Kind regards
EDIT: Macros appear to be slightly different
Posted: Thu Jul 15, 2021 5:07 pm
Hi, yes the macros do look a bit different:
Component differences.png (87.47 KiB) Viewed 10421 times
The addressH and L has been changed to use one input which will cause an issue if not changed.
Hope this helps?
Posted: Fri Jul 16, 2021 10:48 am
by Oscar_T
How can I set the new address in the new macro? it consists of two parts (H and L)
For example 0x38, 0x40, 0x0E, 0x10
maybe 0x38, 78, 0x10, 2 ?
Kind regards
Posted: Fri Jul 16, 2021 12:22 pm
As you already have the AddressHighByte & AddressLowByte
In the Address just enter the HighByte then lowByte straight after.
Eg using your example.
Since 0x38 is H and 0x40 is L.
For UInt address enter 0x3840
Posted: Mon Jul 19, 2021 2:57 pm
by BenR
Hi Oscar,
Sorry for the inconvenience, hopefully the modification allows a bit more flexibility in future allowing for device support with 1 or 2 internal address bytes.
How about this.
0x38, 0x400E, 0x10, 0x02
The device address is as was, the Address high and low bytes have been combined together into a 16-bit value, the Data parameter is as was and the Address Byte count is how many bytes in the internal address: 1 or 2.
Posted: Mon Jul 19, 2021 8:23 pm
by Oscar_T
Hi ben & medelec
Thanks for your explanations. Now everything works!
Kind regards
