initializing "TCP_IP_WIZ810MJ1" kills program
Posted: Sun Aug 01, 2021 4:09 pm
initializing "TCP_IP_WIZ810MJ1" comms component on Arduino Mega kills the program somehow.
the program works in simulation however fails with real hardware for some reason (full freeze), the arduino just stuck at the first block of the code
am using Ethernet Shield r3 based on W5100 from wiznet.
any idea I can try while you look into it ?
can I check the component macro inner workings ?
here's a simple program I tried
