Page 1 of 2
Circularbuffer Getbyte get out wrong data position
Posted: Mon Dec 27, 2021 11:13 am
by lucibel
In my current program I already noticed a problem but I thought it was bad programming on my side, so I bypassed the problem.
I was making a small new program to test it before to include it my curent prog.
I saw that there is a problem with Circularbuffer GetByte()
As you can see, there is 10 data in the buffer and the first on is 56
- data in buffer.jpg (13.22 KiB) Viewed 3521 times
- graphdat.jpg (11.67 KiB) Viewed 3521 times
The problem is when call Getbyte() the first data to get is always the second one (in this case it will be 24) instead of the 1st one who is 56
- data in buffer 1.jpg (35.05 KiB) Viewed 3521 times
It seems that getbyte start always with the second byte in the buffer , it mean with buffer position 1 instead of 0
thx
Re: Circularbuffer Getbyte get out wrong data position
by lucibel
Posted: Mon Dec 27, 2021 1:09 pm
Hi.
The flowchart you posted does not contain the circular buffer component, So I can't tell what you have done.
I don't believe the circular buffer simulation starts at 0 address when first run unless you start with FlushBuffer macro first.
The tool tips for FlushBuffer is:
- FlushBuffer.png (12.23 KiB) Viewed 3513 times
Try that at the start and then see if it does as expected?
It could be the case of a bug and the index is not initialised as 0?
This can be looked into in the new year when we are back at work.
So long as the buffer returns the correct values since indexing is automatic.
Posted: Mon Dec 27, 2021 1:58 pm
by lucibel
hi,
Of course there is a Circular buffer BUT , I used only the debug mode and simulation so the prog sent to you was not current prog saved but only the base! Sorry
please find below after been saved !
Flushbuffer was already used.
No
- Before to getbyte 1st time.jpg (120.31 KiB) Viewed 3509 times
- After getbyte 1st time.jpg (116.89 KiB) Viewed 3509 times
as you can see the first data was 54 instead of 70
thx
Posted: Mon Dec 27, 2021 2:41 pm
by mnfisher
I think this is connected to the fact that the circular buffer can only hold buffer size - 1 data bytes..
I posted a bit about it at
https://www.matrixtsl.com/mmforums/view ... lar+buffer
Posted: Mon Dec 27, 2021 5:23 pm
by lucibel
I tried with buffer size= 11 for 10 data to store and it work's. (store last X value)
- data to store.jpg (63.58 KiB) Viewed 3501 times
I made another test with size 10 for 10 data to store. (store first X value)
9 data was stored and 1 lost
- 9 stored.jpg (61.43 KiB) Viewed 3501 times
The second point is that the Circular buffer on the Console do not reflect the buffer.
10 data sent, only 9 in buffer but 10 in console. This is unsettling to be oblige to use buffer and simulation like this.
- 10 console.jpg (63.04 KiB) Viewed 3501 times
I understand but a FIFO buffer of 10 bytes must be able to store 10 bytes so if it need to calibrate the buffer to 10+1 bytes (in background) instead of 10 to be able to store 10 data, this must be transparent for user (programmer).
Of course I understand well that need 1 more Byte (empty byte) to be able to rotate previous byte ,second byte, etc... But like I said, this must be done in background.
For a buffer of 128 byte, 0 to 127=128 bytes but need 1 more byte (background byte) to store the data during the shift of the register.
I used many FIFO of LIFO in Industrial Automation and the size is always the exact qty of data to store. Because we do not allocate the memory for the Buffer, so it will be better to be able to store X bytes in a X byte buffer.
This is my point of view
This can not be solved by CAL modification ?
Thx
Posted: Wed Dec 29, 2021 11:09 am
by Steve-Matrix
It does look to me like a bug - the first 10 positions of the buffer are correctly initialised in your first loop starting at index 0, but reading back starts at index 1 and so the first value in your buffer is ignored and only 9 bytes are read back before the buffer thinks it is empty. We'll look into this.
Posted: Wed Dec 29, 2021 11:20 am
by Steve-Matrix
Having played with the example on the wiki and with your program, this problem seems to disappear when the size of the buffer is set to one more than the quantity you are wishing to store. So I suggest using that workaround for now.
Posted: Wed Dec 29, 2021 11:53 am
by lucibel
Hi Steve
yes this what I'm doing in the meantime of investigation.
Thx
Posted: Fri Feb 18, 2022 2:55 pm
by lucibel
Hi, what are the news about buffer problem, still no news since end of December?
(Need to setup the buffer size to nbr data to store+1)
This causes another issue :
When discard buffer with get array, oldest entered value is never discarded !
1st test
- Buffer size5, 8 bytes to enter in buffer, 4 Bytes to discard with GetArray --> the oldest byte value who is 4 in the simulation stay in the buffer
2nd test
- Buffer size5, 8 bytes to enter in buffer, 3 Bytes to discard with GetArray --> the oldest byte value who is 4 in the simulation stay in the buffer
then at the next first Buffer PutByte, the oldest byte is overwrite !!!
Please check ASAP, it's already difficult to work with data so if in addition, the buffer doesn't work, it's a nightmare!!!
