Page 2 of 3
Re: TM1637
Posted: Wed Feb 25, 2026 12:23 am
by chipfryer27
I don't have the hardware to test with, but the "count" chart simulates OK in v11 (if brightness is set to high value).
Can you try a one-second flash test on hardware just as a sanity check?
Re: TM1637
Posted: Wed Feb 25, 2026 12:33 am
by ELECTRONICA67
Hola
hize la prueba de 1 segundo con el relay y bien
Re: TM1637
Posted: Wed Feb 25, 2026 8:58 am
by chipfryer27
If that's working OK then your oscillator and chip are running at the correct speed.
As your chart simulates in v11 I can only suggest double checking all hardware connections. If you have a logic analyser / scope you could check for activity on your Data and Clock pins (B1 / B2).
Re: TM1637
Posted: Wed Feb 25, 2026 9:16 pm
by ELECTRONICA67
Hola,
Estoy dejando una sola tarjeta para prueba de que esta bien conectado y configurado, en este ejemplo es uno que tenia guardado hace 1 o 2 aƱos, tiene un conteo : count = count + 1 y si trabaja correctamente en hardware
Saludos
Re: TM1637
Posted: Wed Feb 25, 2026 9:22 pm
by ELECTRONICA67
Hola
En este quiero leer un valor de una memoria eeprom, en simulacion trabaja bien, pero en hardware no encienden los display, publico la fotografia utilizando la misma tarjeta
Saludos
Re: TM1637
Posted: Wed Feb 25, 2026 9:35 pm
by chipfryer27
Your latest chart seems to have an issue in that I can't see the display, just the "outline".
Anyway I don't think I have your chip but I can test the component on another PIC to check activity. Probably not until the weekend though.
Re: TM1637
Posted: Wed Feb 25, 2026 9:44 pm
by ELECTRONICA67
Hola
Tengo 3 dias tratando de visualizar el numero guardado en la memoria eeprom, pero no he podido lograr que los display se enciendan, pero en simulacion funciona correctamente; anteriormente me ayudaron a que los digitos no usados se apagaran para ahorro de baterias, aqui incluyo ese programa, pero tampoco logro que los display se enciendan
Saludos
Re: TM1637
Posted: Wed Feb 25, 2026 9:50 pm
by ELECTRONICA67
Hola,
Si, en el programa que si funciona en hardware, no se puede visualizar el grafico del componente (display) en la pantalla de Flowcode en simulacion, por eso creo hay algun error en el componente actual y creo tambien en Flowcode 11, en el que estoy probando es Flowcode 10
Saludos
Re: TM1637
Posted: Wed Feb 25, 2026 9:53 pm
by ELECTRONICA67
Hola
Te estoy muy agradecido que estes ayudando con este problema
Best Regards
Re: TM1637
Posted: Sun Mar 01, 2026 7:00 am
by ELECTRONICA67
I had to import a program from a previous version that included the TM1637 into Flowcode 10 for the display to work correctly.
The component's image is slightly distorted, but it works fine in hardware. I don't know if this is the only problem I have.
Best Regards
