Custom interrupt - help
Posted: Sun Jan 16, 2022 2:23 pm
working with a PICF1615324 and using the internal comparitor. I think I have this part working.
There is an option to trigger an interupt when the comparitor changes state.
How would i go about this in FC, use the custom Interrupt I guess...
I'm not looking for help on this chips specific interrupt but what in general I should be doing to get a custom interupt to work.
Enable Code. Set the required register bits for correct operation of the interupt. Such as...
Handler Code. Is this what to do when the interrupt is triggered?
If I have a macro called "TmrStart" I should insert...
do I need to do anything else?
thanks, J.
st_bit(CM1CON0,C1ON);
st_bit(CM1CON0,C1POL);
st_bit(CM1CON1,C1INTP);
st_bit(PIE2,C1IE);
st_bit(INTCON,PEIE);
st_bit(INTCON,GIE);If I have a macro called "TmrStart" I should insert...
FCM_TMRSTART();thanks, J.
