Q about the thermistor component
Posted: Mon Feb 28, 2022 9:15 pm
				The default thermistor component appears to be a positive coefficient thermistor. How do i change the component to use a negative coefficient thermistor? Is it as simple as entering the resistance values to suit the one I have or is there more required?
Im using what I think is a vishay thermistor which is 10k at 25 deg but I'm having difficulty finding a table which shows the resistance at the different temperatures. Dont know where i got them but its all i have atm so if anyone has a table Id be grateful if you would share. I have the attached datasheet but its not easy to interpret
Also how can i get my display to show the deg symbol ° (alt 248) its just showing 3 horizontal lines in both simulate and display?
N
N
