PICO toolchain on Windows 11
Posted: Mon Mar 28, 2022 4:17 pm
I have all toolchains working except the Pico toolchain…
I have followed the PDF setup guide…
I have installed: -
> GNU Arm Embedded Toolchain 10.3-2021.10
> Cmake 3.20.5
> Visual Studio Build Tools 2019 (I also have 2022) (2022 Was already installed)
> Visual Studio Community 2019 (I also have 2022) (2022 Was already installed)
> Python 3.7.3 (64-bit)
> Git 2.35.1.2
I am using: -
> Windows 11
> Flowcode 9.2.0
Error from compiler below.
Thanks,
Paul
I have installed: -
> Cmake 3.20.5
> Git 2.35.1.2
I am using: -
> Windows 11
> Flowcode 9.2.0
Thanks,
Paul
Target folder: C:\PICO\TestCode
Source name: C:\PICO\TestCode\Flowcode11.fcfx
Title:
Description:
Device: PICO.PICO.Raspberry_Pi_Pico
Generated by: Flowcode v9.2.0.33
Date: Friday, March 25, 2022 21:58:16
Users: 1
Registered to: xxx (xxx)
Licence key: xxx
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat "C:\PICO\pico-sdk\" "Flowcode11" "C:\PICO\TestCode\"
C:\PICO\TestCode>REM CRC: 11E85D0BF540A03612B9D5AB8A950728A3654FDC084B783F85B503651504FC6E8DA967745A187CF8FECF9115B25085A2774D1D3D69D8A99EE7320EAE740A5DB66BD212DE98DE91D9E3564078A19D1616A5C2ACA5856A86664D00059D79589982019B1EBDA9F75E245824CF181DE22D23B9DE25CDF0E36405D9066202E94705CBBDB038842E43FA4AAC72934211FD4B5DCC661788BEC7C91A063848616D51551DB978AC1A4BAF29AD4517DCDD22FC70DE135D32748FB3D1732C3050DA273BE4EE39DD52E8224900600B1F9528E97AB0BA001B0922CEB719397C7C0C9FABE651313F9A05C84301D1C0
C:\PICO\TestCode>REM REVISION: 2.0
C:\PICO\TestCode>REM GUID: 9EF5601F-D979-495F-89EB-F1C4F35D9212
C:\PICO\TestCode>REM DATE: 30\07\2021
C:\PICO\TestCode>REM DIR: FCD\PICO\batch\pico_build.bat
Building Flowcode11 ...
** Visual Studio 2019 Developer Command Prompt v16.9.18
** Copyright (c) 2021 Microsoft Corporation
PICO_SDK_PATH is C:/PICO/pico-sdk
PICO platform is rp2040.
PICO target board is pico.
Using board configuration from C:/PICO/pico-sdk/src/boards/include/boards/pico.h
TinyUSB available at C:/PICO/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040; enabling build support for USB.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/PICO/TestCode/Flowcode11
Microsoft (R) Program Maintenance Utility Version 14.28.29921.0
Copyright (C) Microsoft Corporation. All rights reserved.
[ 1%] Performing configure step for 'ELF2UF2Build'
-- The C compiler identification is MSVC 19.31.31105.0
-- The CXX compiler identification is MSVC 19.31.31105.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.31.31103/bin/Hostx64/x64/cl.exe
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.31.31103/bin/Hostx64/x64/cl.exe - broken
CMake Error at C:/Program Files/CMake/share/cmake-3.20/Modules/CMakeTestCCompiler.cmake:66 (message):
The C compiler
"C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.31.31103/bin/Hostx64/x64/cl.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/PICO/TestCode/Flowcode11/elf2uf2/CMakeFiles/CMakeTmp
Run Build Command(s):nmake -f Makefile /nologo cmTC_63181\fast && "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29910\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTC_63181.dir\build.make /nologo -L CMakeFiles\cmTC_63181.dir\build
Building C object CMakeFiles/cmTC_63181.dir/testCCompiler.c.obj
"C:\Program Files\CMake\bin\cmake.exe" -E cmake_cl_compile_depends --dep-file=CMakeFiles\cmTC_63181.dir\testCCompiler.c.obj.d --working-dir=C:\PICO\TestCode\Flowcode11\elf2uf2\CMakeFiles\CMakeTmp --filter-prefix="Note: including file: " -- "C:\PROGRA~1\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.31.31103\bin\Hostx64\x64\cl.exe" @C:\Users\PAULSH~1\AppData\Local\Temp\nm6817.tmp
testCCompiler.c
Linking C executable cmTC_63181.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vs_link_exe --intdir=CMakeFiles\cmTC_63181.dir --rc=C:\PROGRA~2\Embarcadero\Studio\21.0\bin\rc.exe --mt="C:\PROGRA~2\Windows Kits\10\bin\10.0.22000.0\x86\mt.exe" --manifests -- "C:\PROGRA~1\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.31.31103\bin\Hostx64\x64\link.exe" /nologo @CMakeFiles\cmTC_63181.dir\objects1.rsp @C:\Users\PAULSH~1\AppData\Local\Temp\nm6857.tmp
LINK Pass 1: command "C:\PROGRA~1\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.31.31103\bin\Hostx64\x64\link.exe /nologo @CMakeFiles\cmTC_63181.dir\objects1.rsp /out:cmTC_63181.exe /implib:cmTC_63181.lib /pdb:C:\PICO\TestCode\Flowcode11\elf2uf2\CMakeFiles\CMakeTmp\cmTC_63181.pdb /version:0.0 /machine:x64 /debug /INCREMENTAL /subsystem:console kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib /MANIFEST /MANIFESTFILE:CMakeFiles\cmTC_63181.dir/intermediate.manifest CMakeFiles\cmTC_63181.dir/manifest.res" failed (exit code 1120) with the following output:
testCCompiler.c.obj : error LNK2001: unresolved external symbol _RTC_InitBase
testCCompiler.c.obj : error LNK2001: unresolved external symbol _RTC_Shutdown
LINK : error LNK2001: unresolved external symbol mainCRTStartup
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\kernel32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\user32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\gdi32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\winspool.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\shell32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\ole32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\oleaut32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\uuid.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\comdlg32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Windows Kits\10\lib\10.0.22000.0\um\x86\advapi32.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29910\lib\x86\MSVCRTD.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
cmTC_63181.exe : fatal error LNK1120: 3 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files\CMake\bin\cmake.exe"' : return code '0xffffffff'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29910\bin\HostX86\x86\nmake.exe"' : return code '0x2'
Stop.
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:2 (project)
-- Configuring incomplete, errors occurred!
See also "C:/PICO/TestCode/Flowcode11/elf2uf2/CMakeFiles/CMakeOutput.log".
See also "C:/PICO/TestCode/Flowcode11/elf2uf2/CMakeFiles/CMakeError.log".
NMAKE : fatal error U1077: 'echo' : return code '0x1'
Stop.
Stop.
Stop.
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat reported error code 0x1
Autoclose turned off
FINISHED
