ESP32-S2-WROOM
Posted: Wed Jan 13, 2021 6:04 pm
by minolta
Question:
is ESP32-S2-WROOM supported by Flowcode 9?
i want to use WLAN_ESP32 component with this module
Re: ESP32-S2-WROOM
Posted: Wed Jan 13, 2021 8:00 pm
by BenR
We haven't tested the s2 version yet. Hopefully it should work ok but you will have to let us know. I'll see if I can get my hands on one to test.
Re: ESP32-S2-WROOM
Posted: Wed Jan 13, 2021 8:34 pm
by minolta
I have to admit that this the first time when i use ESP32 modules.
My intention is to setup a communication between 2 modules, connected to my wi-fi router.
I do not know if this can be done with wlan esp32 library.
But, because i like to try new things i will order 2 modules and do some tests.
I'll let you know how it goes.
TIberiu
Re: ESP32-S2-WROOM
Posted: Wed Jan 13, 2021 10:07 pm
by BenR
If you are just getting started then I might suggest using the standard v1 ESP32 module. There are lots of boards with the v1 module on.
The IDF compiler that we recommend says it is not compatible with the S2 so there are likely going to be some issues and if you're just getting started then this could be offputting.
Re: ESP32-S2-WROOM
Posted: Sun Jan 31, 2021 12:13 pm
by Verteyko
Добрый день. Не могу прошивать модуль ESPЗ2 DEVKIT1 через USB. Все инструменты скачал и устоновил. Дает ошибку code 0х1
Edit[p.erasmus] English Translation
Good day. I can not flash the ESPЗ2 DEVKIT1 module via USB. I downloaded and installed all the tools. Gives error code 0x1
Re: ESP32-S2-WROOM
Posted: Sun Jan 31, 2021 3:29 pm
by p.erasmus
Добрый день
Команда будет смотреть и сообщать
Re: ESP32-S2-WROOM
Posted: Tue Feb 02, 2021 1:18 pm
by BenR
Здравствуйте,
Как называется ваш проект Flowcode? Не могли бы вы прикрепить его к форумам, чтобы мы могли увидеть, является ли это чем-то особенным для проекта.
What's the name of your Flowcode project? Can you attach it to the forums so we can see if it's something specific to the project.
