uart
Posted: Thu Aug 18, 2022 7:45 am
by asmatec
hello, can you check the uart rs232 component, the bauds selected in flowcode do not correspond to the real ones, if we select 9600 they correspond to 2400, 19200 to 4800, 38400 to 9600 etc... thanks
Re: uart
Posted: Thu Aug 18, 2022 7:54 am
Have you run a
one-second flasher test to check your hardware is running at the correct speed?
If you have and it's correct, what target device are you using that has the board rate issue?
Re: uart
Posted: Thu Aug 18, 2022 10:18 am
by asmatec
It's already solved, I had a configuration problem in the oscillator, sorry for the inconvenience! Thanks a lot
