Arduino Uno analogue input issue
Posted: Wed Oct 05, 2022 2:22 pm
Hi, I have written a program using the Arduino Uno R3 smd version and FC9. It simulates perfectly but when I connect the Arduino in circuit it does not seem to respond to the analogue inputs at all. For example I can o/c all the analogue inputs and the program runs through the "Start up Macro" and on to the main program before it then fails. The "Start up Macro" uses a check to make sure the 4 inputs are ALL within the defined parameters before moving on to the main program and with them all o/c this should not be possible. I have also tried varying the inputs too with no success!
To add to the frustration I tried to use a BL0061 with the code modified to suit the board as an alternative but, the code failed to be executed with error messages referring to code e.g. Output / Decision etc.
I am under pressure time wise to get this running so any assistance would be greatly appreciated.
I have attached the both programs for you to see.
