PIC16F1717
Posted: Mon Oct 10, 2022 12:46 pm
by Maverick
Is there a way to program a PIC16F1717 (possibly using an alternative part) using either an EB006 or BL0080 as the part does not appear on MLOADER list for either dev board
link to PIC16F1717 Data Sheet
http://ww1.microchip.com/downloads/en/D ... 01740C.pdf
Re: PIC16F1717
Posted: Mon Oct 10, 2022 1:58 pm
by Maverick
I selected a 16f1936 part on mloader and managed to program the 16F1717 with no errors and it seemed to run the code. Is there anything that could likely go wrong with the programmed chip doing this?
Re: PIC16F1717
Posted: Mon Oct 10, 2022 2:20 pm
by Steve-Matrix
That's interesting - thanks for letting us know.
A few things that could go wrong include parts of the chip memory not being updated and issues with the configuration word. But if it seems to work and you have tested your program fully when it is running in the chip then it should be fine.
Re: PIC16F1717
Posted: Mon Oct 10, 2022 2:22 pm
by BenR
That's excellent well done, shoudn't be any issues, if the codes gone in and is working ok then the erase, program and config should all have been done correctly and you should be fine.
Aha Steve beat me to it
Re: PIC16F1717
Posted: Tue Oct 18, 2022 5:43 pm
by Maverick
Unfortunatly, not everything works as it's meant to, I will try other options.
Is there an alternative to mloader using pickit3 without installing mplab.
Re: PIC16F1717
Posted: Tue Oct 18, 2022 6:15 pm
Hello Maverick.
This is one alternative for PICkit3.
It does look like the 16F1717 is included within the
device-supported list
