FC9 vs. FC toolchain and Microchip Pro-Compiler
Posted: Mon Feb 01, 2021 11:08 am
by dvcam99
Hello Matrix Team,
I just purchased FC9 Prof. Version and I want to download the PIC8 Toolchain shortly.
Three questions came up!!
1. Will this new FC9 Pic toolchain may create a conflict with my existing FC8 Prof. Pic-8 toolchain??
2. I´m using the Mircrochip Pro-Compiler version 1.45 with my old FC8. Will this may create problems with the new FC9 compiler toolchain.
3. Will the Microchip Pro-Compiler work with FC9 too?
Tanks in advance
Dirk
Re: FC9 vs. FC toolchain and Microchip Pro-Compiler
Posted: Mon Feb 01, 2021 12:39 pm
by Steve-Matrix
dvcam99 wrote: ↑
There should be no conflict. We have been using both toolchains side-by-side without problem.
dvcam99 wrote: ↑
I’ve not specifically tested this, but I can’t see there being a problem.
dvcam99 wrote: ↑
Yes and no. FC9 uses v2 of the compiler and supports the newer chips. The code generated by Flowcode should work on both v1 and v2 compiler toolchains, but we test v9 mainly with the v2 compiler and you would also lose support for the newer chips. However, your pro compiler version will add code optimisations and have other benefits for you.
It should be relatively simple to switch which toolchain is being used by editing the location in the “locations” tab of Flowcode’s global options.
Posted: Mon Feb 01, 2021 6:01 pm
Hi Steve,
Steve-Matrix wrote: ↑
I did not think 2 was included in this release?
Posted: Mon Feb 01, 2021 6:28 pm
by p.erasmus
I aslo did not know this I suppose we can down load the V2 from the FC web page
:D
Posted: Mon Feb 01, 2021 6:35 pm
by BenR
I believe v9 will work with v1 or v2 compiler. If you have v1 installed from v8 then it will work fine with this. If you download the compiler from the flowcode.co.uk site then that will be v2.
Posted: Mon Feb 01, 2021 8:17 pm
Thanks Steve & Ben
BenR wrote: ↑
That's why I stated about v1 as originally downloaded from matrixtsl site.
However, I don't believe the batch file is correct.
Loaded a flowchart and compiled with the default v2 batch file:
@REM $(chip) "$(outdir)" "$(target)"
@PUSHD %~2
%~dp0..\pic\bin\xc8.exe --chip=%~1  "%~3.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
@POPD
@IF %ERRORLEVEL% NEQ 0 GOTO Error
@ECHO.
@ECHO Compilation successful!
@EXIT 0
:Error
@ECHO.
@ECHO Error returned from [xc8.exe]
@EXIT %ERRORLEVEL%
Results:
Memory Summary:
    Program space        used  3612h ( 13842) of  4000h bytes   ( 84.5%)
    Data space           used    E5h (   229) of   300h bytes   ( 29.8%)
    Configuration bits   used     7h (     7) of     7h words   (100.0%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    ID Location space    used     0h (     0) of     8h bytes   (  0.0%)
    Data stack space     used     0h (     0) of   212h bytes   (  0.0%)
Tried again with batch file from here:
@PUSHD %~2
"C:\Program Files (x86)\Microchip\xc8\v2.00\bin\xc8-cc.exe" -mcpu=%~1 "%~3.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
@POPD
@ECHO.
@EXIT 0
:Error
@ECHO.
@EXIT 1
Aa
Results are:
Memory Summary:
    Program space        used  2C9Ch ( 11420) of  4000h bytes   ( 69.7%)
    Data space           used    C7h (   199) of   300h bytes   ( 25.9%)
    Data stack space     used     0h (     0) of   22Fh bytes   (  0.0%)
Posted: Wed Feb 03, 2021 8:37 pm
by dvcam99
First many thanks for your feedback friends!!
I will give it a try in the next 2 or 3 weeks.
I´ll give you d feedback then.
BR
Dirk
Posted: Mon Mar 01, 2021 8:05 pm
by dvcam99
Hello together,
like I promised some weeks ago here is my feedback.
1. Microchip Pro-Compiler 1.45 with my old FC8 and new FC9 is working fine!!
2. No problems observed with the toolchain too.
Just finished my new project!!
Great job Matrix Team!!
THX
Dirk
