^ (1504) the PIC18 extended instruction set was enabled but is not supporte
Posted: Mon Apr 10, 2023 2:47 pm
by solozerouno
error when i compiling led with pic18f45k22
Re: ^ (1504) the PIC18 extended instruction set was enabled but is not supporte
Posted: Mon Apr 10, 2023 2:50 pm
by solozerouno
(908) exit status = 1
Posted: Mon Apr 10, 2023 11:07 pm
This is not a bug, so I have moved your post from the bugs section
The Extended instruction set is not required or supported by Flowcode
You will need to go into the Build > Project Options and change Extended instruction Set Enable bit from Enabled to Disabled.
For any future posts, it would help if you selected the 9 or 10 post icon, depending on what Flowcode version you have.
