empty calculation after rename variable?
Posted: Fri May 17, 2024 5:26 pm
by stefan.erni
Hi to all
In a working program i can not change the calculation anymore. It's empty.
Before i have rename the variable from themp_16 to temp_16.
Maybe a problem?
Re: empty calculation after rename variable?
Posted: Mon May 20, 2024 8:37 am
by Steve-Matrix
Hi Stefan,
There is a small issue with the calculation icon window in the latest v10.1.1 version of Flowcode. If the first line of a calculation is a blank line, then the calculation icon dialog will be empty when it is opened, and if OK is then pressed, the calculation icon contents will be cleared.
The workaround for this is to always have something at the beginning of the list of calculations. If you want a blank line at the beginning of the list, then you should use "//" instead.
Posted: Mon Jun 10, 2024 9:47 am
Any current V10 projects can be easily fixed, if you want all the lines visible again.
Keep a backup copy just in case.
Open your .fcfx project file with a text editor like Notepad++.
select
Search >
Replace
Within
Find what: box enter
Leave
Replace with: blank.
Select Replace
All
Finally Select save.
Posted: Mon Jul 01, 2024 6:55 pm
by jgu1
Hi Martin!
When will this bug be fixed please.
Br Jorgen
Posted: Tue Jul 02, 2024 9:05 am
by Steve-Matrix
We will try to get a release out soon. Hopefully this month or next.
Posted: Tue Jul 02, 2024 7:49 pm
by jgu1
Thank you Steve
Posted: Fri Jul 05, 2024 4:03 pm
by Steve-Matrix
Hello @jgu1. I have sent you a PM about this issue.
Posted: Sat Jul 06, 2024 9:11 pm
by jgu1
Hi Steve, I have answer you PM
