Page 1 of 3
Components not loadable / BMP280 no values
Posted: Sun Jun 23, 2024 10:46 am
by Jorg_Guldner
Hello!
Please use the attached file and try to load the component "BMP280" into the program. I can`t load this one and others. What happens there?
A new blank start lets all load. The component "BMP280" gives no values to the float variable. "BME280" is working. Can you have a look to them?
Jörg
Re: Components not loadable / BMP280 no values
Posted: Mon Jun 24, 2024 1:37 pm
by BenR
Are you trying to add the BMP280 onto the 3D panel? It's a 2d only component and so will only work on the new 2d panels. There isn't a 2d panel in your project and so you may need to add one before it starts behaiving correctly. A new project file will automatically have a 2d panel and so may be getting around the problem you're seeing here.
Posted: Tue Jun 25, 2024 5:51 am
by Jorg_Guldner
Hello!
In the attachment is the sensor and oled display on the 2d panel. The temperature is working. The pressure value stays to zero. On the display is only the offset shown. The debugging is very long to see the values.
Posted: Thu Jun 27, 2024 3:15 pm
Hi Jörg
There was a bug within the pressure simulation, which I have fixed
To try the component.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
If you are referring to hardware, then you can increase the oversampling values within the component properties.
If does not work on x16, then you can try a Forced_Read component macro just before the Read Temp and pressure component macros.
Posted: Fri Jun 28, 2024 10:33 am
by Jorg_Guldner
Hello!
I overwrite the attached component from you and start a new project. The pressure stays to zero! The BME280
sensor is working. An idea to look where is the difference between both?
The attached program consist only with the sensor BMP280.
Jorg
Posted: Fri Jun 28, 2024 11:29 am
The issue you are having is you have not added the float variable to the ReadPressureFloat component macro, as a variable for return value is required.
Also you can't use a ForcedRread component macro while Mode within properties is set to Normal.
You must change Mode to Forced
just to try, If I was you, I would remove the ForceRead for now, and add the float variable to ReadPressureFloat component macro.
If does not work then you could increase the Pressure Oversampling
I would also recommend adding a byte variable to the BMP280 Initialise component macro and don't allow the code to continue if the return value is 1.
Posted: Sat Jun 29, 2024 3:09 pm
by Jorg_Guldner
Hi all,
On the display is now the pressure readable. Thanks!
The way what happens:
1.) The component for the simulation is now updated by matrix.
2.) By all the trials I used at last the software with no float-variable setting inside the component. My mistake!
3.) I have flowcode in an own sub directory. Updated the component and nothing happens. The advice to save the component under "program data" directory let me know, that there is a second own directory for components. I think, this was created with the major updates. I paste there the component file, too. Nothing happens in the program.
4.) During flowcode starts, comes the message "refreshing components". But the pressure stays to zero. Removing out the pressure component, closing flowcode, starting flowcode and paste the component again shows now the missed pressure value.
I thought, that the refreshing updates the components, but it isn`t.
Regards Jorg
Posted: Sat Jun 29, 2024 5:52 pm
Hi Jorg
Hi all,
You're welcome, I'm glad you now have the pressure readings,
Yes, that was the only bug I had spotted.
As I stated, if you run an update before the component is added to the database then Flowcode will revert to non-modified component
Don't allow the update until the component has been pushed to the update system.
We are waiting for you to be happy with the component update, before the component is pushed.
Posted: Mon Jul 01, 2024 5:31 pm
by Jorg_Guldner
I think, you misunderstood me. I didn`t do any updates from your server during this testing of the BMP280P. I overwrite only the BMP280P-component file. But the refreshing was not working with the actual fcfx-file, I wrote. Erasing the component inside my software, closing Flowcode, starting again and placed the component new was the way to get it run.
In the simulation, the temperature is set to zero and the value below is zero, too. The pressure is set to 300, but the value below shows zero? Starting the simulation changes not the value below. You must shift the pointer to another value and then the new value is shown below.
Jorg
Posted: Tue Jul 02, 2024 10:14 am
Hi Jorg.
The component I added, was only to fix simulation of pressure values, as it remained at 0
The slider works via an internal API interrupt which detects the slider movement then updates with the current slider value.
When first loaded there would not have been any slider movement therefore the value at the start might not match
I have modified the component so the 300 should be forced on the slider window for pressure after the project is loaded.
The update should be pushed onto the update system today.
