Project Code
Posted: Wed Jul 17, 2024 7:40 pm
Hi All
I was looking for advice too see if the code for my final project will work as expected. It has the following requirements:
>Start that hen operated will operate a relay to open a DAC hopper valve and power a relay to control machinery.
>Stop will stop the machinery running, shut the DAC hopper valve and await a reset and then power a reset required light.
>Micro switch will stop the machinery running, shut the DAC hopper valve and await a reset and then power a reset required light.
>Reset can be operated mid program or after the the stop or microswitch is actuated, it must take the code back to the start and await the start to be pressed again.
