Serial Recieve - String Buffer
Posted: Tue Sep 24, 2024 10:41 pm
I'm still working on a good method to recieved lots of diagnostic strings from a PIC.
My diagnosic message strings are under 40 characters long, with start (~) and end (;) marker characters.
The PIC sends 30 diagnostic message strings as a block of strings every second. There is with about 1ms space between each messge in the block and its sent via Serial @ 115.200 kbit
I did try to recieved them as individual messages but when processing the first string, I loose the later messages.
So I'm thinking about reading in the whole string. 40char * 30 = 1300 characters. Which should be no issue for a PC.
Then split these into seperate messages by looking for the start and end characters.
Maybe run this as an interrupt? I thik it would take about 500ms to recieve all of the data at 115Kbit.
Could this data be saves to a String Buffer? if so, is this something I would need to construct?
Then other parts of the program would read the messages from the buffer and decode them, displaying the data in the various cosoles and graphs.
Any ideas on how to ahcieve this? or a better way to recieve lots of fairly fast data and then break it into usable chunks?
Thanks, j.
Thanks, j.
