error message
Posted: Thu Jan 30, 2025 9:21 am
Can anyone here help me? I always get an error message when compiling, but I don't know exactly what this means and where the error lies...
Thank you very much
Chris
Target folder: C:\Users\Admin\Desktop\Flowprojekte
Source name: C:\Users\Admin\Desktop\Flowprojekte\delete.fcfx
Device: AVR.ATMEGA.ATMEGA8
Generated by: Flowcode v9.3.1.36
Date: Thursday, January 30, 2025 10:15:40
Registriert für: ChrisT66 (50562083)
Lizenzschlüssel:PU90WH
NICHT FÜR KOMMERZiELLE ANWENDUNGEN
https://www.flowcode.co.uk
Using <AVRISPmkII> inbuilt settings for compiler
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" atmega8 "C:\Users\Admin\Desktop\Flowprojekte\delete.elf" "C:\Users\Admin\Desktop\Flowprojekte\delete.c" "C:\Users\Admin\Desktop\Flowprojekte\delete.lst"
C:\Users\Admin\Desktop\Flowprojekte>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D7958998291880A09BBE74CF7BA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EEFF12703F3DAF67B119A5A5B069403B38249A6C4D8A1304B09A437E7E2D43FD26DF891DB3086C82D6
C:\Users\Admin\Desktop\Flowprojekte>REM REVISION: 1.0
C:\Users\Admin\Desktop\Flowprojekte>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
C:\Users\Admin\Desktop\Flowprojekte>REM DATE: 29\03\2021
C:\Users\Admin\Desktop\Flowprojekte>REM DIR: FCD\AVR\batchfiles\avra.bat
C:\Users\Admin\Desktop\Flowprojekte>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-gcc.exe" -mmcu=atmega8 -Os -ffunction-sections -fdata-sections -funsigned-char -o "C:\Users\Admin\Desktop\Flowprojekte\delete.elf" "C:\Users\Admin\Desktop\Flowprojekte\delete.c" -lm -Wl,-gc-sections
C:\Users\Admin\Desktop\Flowprojekte\delete.c: In function 'FCM_RxData':
C:\Users\Admin\Desktop\Flowprojekte\delete.c:5152:24: warning: passing argument 1 of 'FCM_Get16BitValues' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:\Users\Admin\Desktop\Flowprojekte\delete.c:135:6: note: expected 'MX_UINT16 * {aka short unsigned int *}' but argument is of type 'volatile MX_UINT16 * {aka volatile short unsigned int *}'
void FCM_Get16BitValues(MX_UINT16 *FCL_VALUES, MX_UINT16 FCLsz_VALUES);
C:\Users\Admin\Desktop\Flowprojekte\delete.c:5159:24: warning: passing argument 1 of 'FCM_NormaliseData' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
// Name: Loop, Art: Schleife: Schleife .i: 5 times
C:\Users\Admin\Desktop\Flowprojekte\delete.c:136:6: note: expected 'MX_UINT16 * {aka short unsigned int *}' but argument is of type 'volatile MX_UINT16 * {aka volatile short unsigned int *}'
void FCM_NormaliseData(MX_UINT16 *FCL_DATA, MX_UINT16 FCLsz_DATA, MX_UINT16 *FCL_NORMALS, MX_UINT16 FCLsz_NORMALS);
C:\Users\Admin\Desktop\Flowprojekte\delete.c:5159:42: warning: passing argument 3 of 'FCM_NormaliseData' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:\Users\Admin\Desktop\Flowprojekte\delete.c:5164:27: warning: passing argument 1 of 'FCM_GetNormalisation' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
// .normals[.i] = .data[.i]
C:\Users\Admin\Desktop\Flowprojekte\delete.c:129:6: note: expected 'MX_UINT16 * {aka short unsigned int *}' but argument is of type 'volatile MX_UINT16 * {aka volatile short unsigned int *}'
void FCM_GetNormalisation(MX_UINT16 *FCL_DATA, MX_UINT16 FCLsz_DATA, MX_UINT16 *FCL_NORMALS, MX_UINT16 FCLsz_NORMALS);
C:\Users\Admin\Desktop\Flowprojekte\delete.c:5164:45: warning: passing argument 3 of 'FCM_GetNormalisation' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:\Users\Admin\Desktop\Flowprojekte\delete.c: In function 'FCM_Get16BitValues':
C:\Users\Admin\Desktop\Flowprojekte\delete.c:6216:24: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations]
C:\Users\Admin\Desktop\Flowprojekte\delete.c:6209:2: note: containing loop
// Name: Entscheidung, Art: Entscheidung: z1 = 5?
C:\Users\Admin\Desktop\Flowprojekte\delete.c: In function 'FCM_NormaliseData':
C:\Users\Admin\Desktop\Flowprojekte\delete.c:6246:21: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations]
C:\Users\Admin\Desktop\Flowprojekte\delete.c:6239:2: note: containing loop
c:/program files (x86)/flowcode/common/compilers/avrv5/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: C:\Users\Admin\Desktop\Flowprojekte\delete.elf section `.text' will not fit in region `text'
c:/program files (x86)/flowcode/common/compilers/avrv5/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: region `text' overflowed by 176 bytes
collect2.exe: error: ld returned 1 exit status
Error returned from [avr-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avra.bat Hat den Fehlercode 0x1 gemeldet
Thank you very much
Chris
