REMAP TX/RX PIN IN WLAN-ESP8266 COMPONENT
Posted: Fri May 16, 2025 10:12 pm
by SILVESTROS
Dear Sirs,
How to change and store TX/RX REMAP pins in Properties--->Connections of WLAN-ESP8266 component ? In a FC10 project I use 2 channels UART to connect PIC18F47K40 with ESP8266..I try to remap TX/RX pins in channels 1/2 at Properties , I change port pins in Connections ,but I can't store that in Properties..
Thanks in advance
Basil
Re: REMAP TX/RX PIN IN WLAN-ESP8266 COMPONENT
Posted: Fri May 23, 2025 11:38 am
by BenR
Hi Basil,
Not sure what you mean here. do you mean the connections are lost or simply you don't have access to remap the pins? Can you attach your project so we can have a look?
I've tried to replicate the problem but it all seems to be working ok.
Posted: Mon May 26, 2025 8:03 pm
by SILVESTROS
Dear Ben,
thanks for your answer..The connections are lost after REMAP pins in properties. how can store the settings ? only with exit from properties ?
Basil
Posted: Tue May 27, 2025 8:10 am
Hi Basil.
I have tried and saved different remapped pins and they save OK, even after restarting Flowcode.
Or are you referring to the exposed SDA pin to the root?
Do you want all connections exposed?
Please can you give as much detail as possible for us to help you.
