WS8211 component encountered an error and cannot be used anymore (solved)
Posted: Fri Oct 17, 2025 2:01 am
by niedian
Hello, this error occurred after upgrading. What should I do,
In the first few days, after reporting to WS8211, I sent the file you posted on the forum(
download/file.php?id=10494 )I copied and pasted it into% ProgramData% \ MatrixTSL \ FlowcodeV10 \ Components, and encountered the error after upgrading today. What should I do? Acknowledgments
Re: Hello, this error occurred after upgrading. What should I do
Posted: Fri Oct 17, 2025 2:04 am
by niedian
The upgrade is proceeding normally, but when adding the ws8211 component after the upgrade, the above error message appears
Posted: Fri Oct 17, 2025 2:14 am
by niedian
After deleting LEDw_S2811.fcpx and upgrading it again, the error shown in the above diagram still occurs。
Re: WS8211 component encountered an error and cannot be used anymore
Posted: Fri Oct 17, 2025 9:50 am
Hi niedian
Many thanks for the spot.
I can replicate the issue, so I have attached an updated version for you to try.
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
Posted: Fri Oct 17, 2025 10:06 am
by niedian
I did it your way and it's back to normal. You're amazing, thank you very much.
Posted: Fri Oct 17, 2025 10:41 am
That's great, your welcome
Thanks for letting me know.
I will make sure the updated version goes to the component database.
Posted: Fri Oct 24, 2025 3:20 am
by niedian
After today's upgrade, ws2811 still has the above-mentioned issues.
Posted: Fri Oct 24, 2025 3:37 am
by chipfryer27
Please reread Martin's post of above. He will work on having the fix published. Meanwhile, until it is published, if you update then you will revert back to the non working version.
If you download Martin's "fix" as per above, then the chart will work again.
It takes time for your fix to become "live", so to speak.
