ESP32 Soc Support
Posted: Tue Jun 08, 2021 10:53 am
by Oscar_T
I am considering to use for a new project esp32-s2 (56pin) only the soc.
I would like to understand
  • Does Flowocode properly support the soc?
  • Is there a program to download the compiled file inside the soc or do I have to replicate the usb uart bridge that is on the development boards?
The idea is to use the usb port for field updates
Thank you
Re: ESP32 Soc Support
Posted: Tue Jun 08, 2021 11:16 am
by BenR
We have not tested Flowcode with the S2 device. Hopefully it should work fine and will be supported in future but at the moment it is untested by us. I'll see if I can get my hands on a couple.
Using Flowcode with the ESP32 SoC i.e. the raw chip will be fine but yes you need to replicate the UART to USB bridge for programming. This could be done by bringing the nessisary pins to a connector on the board so you don't have to fit the USB to UART IC directly onto your circuit board.
Posted: Tue Jun 29, 2021 4:54 pm
by Oscar_T
hello
i'm try to using this board ESP32-DevKitC-32E
https://www.mouser.it/ProductDetail/Esp ... WDrQ%3D%3D
but when i compiling
"Build Failed
Autoclose turned off
is this board not compatible?
Kind regards
Posted: Tue Jun 29, 2021 5:15 pm
by BenR
Please can you post your project file and I'll investigate for you.
Posted: Tue Jun 29, 2021 5:18 pm
by Oscar_T
This is the project
Posted: Tue Jun 29, 2021 5:50 pm
Hi, Oscar_T
I have compiled your flowchart to hex successfully.
It could be an issue with your installation or you have not configured Flowcode correctly?
Have you followed this ESP32 Setup guide
With Flowcode setup have you got the ESP32 path, entered in Global, location tab?
Also you will need select Build ribbon & select Project Options.
At the bottom right, under Programming Port
Make sure you have the correct programming port selected and it not showing n/a
Could you also post a copy of the compiler text file.
The file called
ESP32_003.msg.txt
and it's located in the same directory as your Flowchart.
Posted: Tue Jun 29, 2021 6:15 pm
by Oscar_T
Hi Medelec
This problem I have only with this pcb which differs from the previous one for the final E
If I connect the old pcb everything is ok
Posted: Tue Jun 29, 2021 6:55 pm
by Oscar_T
Hi all
Reading the compiler log carefully was a problem with a folder.
Everything seems to be working fine
Posted: Tue Jun 29, 2021 7:56 pm
Hi Oscar,
Glad you spotted the issue from the compiler text file.
Thanks for keeping us updated.
