SPI Slave Compiler gives an error
Posted: Wed Jan 05, 2022 6:36 pm
by Osta
Happy New Year everyone!!!
I use ATMEGA 128 controller.
When using interrupts and the SPI Slave macro compiler gives an error.
TEST.c:(.text.FCM_SSP+0x0): undefined reference to `FC_CAL_SPI_Slave_RxByte_1'
Re: SPI Slave Compiler gives an error
Posted: Fri Jan 07, 2022 9:50 am
by BenR
Hello and Happy new year :D
It looks like SPI slave functionality is not currently impemented on the AVR target devices.
I'll have a look for you now and see if I can add it in for you.
Posted: Fri Jan 07, 2022 10:23 am
by BenR
Hello again,
Right it's compiling correctly now and I've pushed the update to the library update system.
Let us know how you get on.
Posted: Fri Jan 07, 2022 2:09 pm
by Osta
Thanks a lot !!!!!!!
I updated the libraries and everything worked!
Best wishes to you and your team! ;)
Posted: Fri Jan 07, 2022 7:14 pm
by Osta
Again, error, but in another project with ATMEGA 128
Interrupts do not work ....
Posted: Sat Jan 08, 2022 12:23 pm
by Osta
Before using the Flowcode macros, the С code was written,
But after the use of macros Flowcode, the compiler began to issue an error!
As a result, neither macros do not work С code !!!
Posted: Sat Jan 08, 2022 12:32 pm
by Osta
I do not know what to do...
How to return to the scene when did you work with the code?
Posted: Sat Jan 08, 2022 1:35 pm
Hi.
The compiler is complaining that you have got the same interrupts enabled in Main and COXPAH.
If you remove one it should compile for you.
Posted: Sat Jan 08, 2022 3:33 pm
by Osta
Right!!!
Thanks a lot!!!
