E:\Program Files (x86)\Flowcode 6\compilers\avr\batchfiles\avrc.bat reported error code 1
I think the batch file is configured wrong
[Programmer=AVRispMKII
@SET DUDEPort=usb
@SET STKPort=COM7
@SET STKPath="E:\Program Files (x86)\Flocode 6\avr\bin\Stk500.exe"
@REM Select programmer utility
@IF "%1" == "STK500" GOTO STKprog
@REM -------------- AVRDUDE programmer --------------
@SET Fuse1=
@SET Fuse2=
@SET Fuse3=
@REM %6 is the flag to send fuse data instead of the program
@IF "%6"=="1" GOTO Config
:ProgFlash
@SET AVRDUDEcmd="%~dp0..\bin\avrdude.exe" -p %2 -P %DUDEPort% -c %Programmer% -U flash:w:%5
@SHIFT
@GOTO Send
:Config
@SET AVRDUDEcmd="%~dp0..\bin\avrdude.exe" -p %2 -P %DUDEPort% -c %Programmer% -u
@REM %7 is the number of fuses present
@IF "%7"=="1" GOTO ConfigOneFuse
:ConfigThreeFuses
@IF NOT "%8"=="-1" SET Fuse1=-U hfuse:w:%8:m
@IF NOT "%9"=="-1" SET Fuse2=-U lfuse:w:%9:m
@SHIFT
@IF NOT "%9"=="-1" SET Fuse3=-U efuse:w:%9:m
@GOTO Send
:ConfigOneFuse
@IF NOT "%8"=="-1" SET Fuse1=-U fuse:w:%8:m
@SHIFT
@GOTO Send
:Send
@REM Now add any additional command line parameters here
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
@SHIFT
%AVRDUDEcmd% %Fuse1% %Fuse2% %Fuse3% %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
@IF %ERRORLEVEL% NEQ 0 GOTO DUDEError
@GOTO End
:DUDEError
@ECHO.
@ECHO Error returned from [avrdude]
@EXIT 1
:STKprog
@REM -------------- STK500 programmer --------------
@SET STK500cmd=%STKPath% -c%STKPort% -d%3 -e -if%4 -pf -vf
%STK500cmd%
@IF %ERRORLEVEL% NEQ 0 GOTO STKError
@GOTO End
:STKError
@ECHO.
@ECHO Error returned from [stk500]
@EXIT 1
:End
@ECHO.
@ECHO Programming successful!
@EXIT 0ode]
error code 1
Re: error code 1
What chip are you trying to program and can you post up your compiler messages containing the error so we can see what command arguments are being passed.
