DS18B20 Temp sensor
keejay
Flowcode v5 User
Been thanked: 15 times
DS18B20 Temp sensor
Post by keejay »
I am trying to get a DS18B20 temp sensor to work with FC6. I have used the example file and tweaked it for my setup, but the only value displayed on the gLCD is 32767.5. The one-wire component macro in FC6 has an option for the DS1820 which is a bit different to the DS18B20.
Has anyone managed to get the DS18B20 to work in FC6? Any help will be appreciated.
keejay
Flowcode v5 User
Re: DS18B20 Temp sensor
Post by keejay »
With the exact same hardware setup, I can get it to work 100% with FC5. Seems that the FC6 component macro is obviously not compatible with the DS18B20. The FC5 component macro specifically states that it is for the DS18B20 and the FC6 states that it's for the DS1820. Is this correct?
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Post by hyperion007 »
I was using this DS18B20 sensor just last week. I didn't use the parasitic power to supply it.
Can you please attach your FC program file and I'll have a look. Also if you could show how it is connected (between DS18B20/MCU/Vdd/Vss etc.) that would help.
keejay
Flowcode v5 User
Post by keejay »
Thanks for the reply. I'm pretty sure the hardware is ok because it works great with FC5. As soon as I program the exact same hardware setup with FC6 .hex file then it doesn't work. I've attached the FC6 file here for you to check if you'd like. I am also not using parasite power, but the conventional power supply with the 4k7 resistor included.
Thanks again..
DS18B20_Test_v6.fcfx
(8.2 KiB) Downloaded 1086 times
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
perhabs it helps
attached is a Example with a PIC18F2550 and a DS18B20 Temp Sensor on RA3
i have a RS232 no LCD conected, because i send this over ´xbee 868 pro'..
and - i have not used the one wire icon ;-)..
but this you can change by yours..
one Problem ( i puzzled where the mistake is perhabs Martin can look to this - i am not so fit in Flowcode )
allways full DIGI
example:
Celsius : 22.0
Celsius : 21.0
Celsius : 23.0
Celsius : 19.0
never show
Celsius : 22.3
Celsius : 21.2
Celsius : 23.4
Celsius : 19.5
i think i have a mistake in convert ..
..i have make paused in this becaue i need the help in INTCON2Bits...
http://www.flowcode.co.uk/mmforums/viewt ... =7&t=15260
Best wishes
Rudi
Rudi
Post by Rudi »
keejay wrote:Thanks for the reply. I'm pretty sure the hardware is ok because it works great with FC5. As soon as I program the exact same hardware setup with FC6 .hex file then it doesn't work. I've attached the FC6 file here for you to check if you'd like. I am also not using parasite power, but the conventional power supply with the 4k7 resistor included.
Thanks again..
Hi keejay,
i have test your flowchart. This runs very well with FC 6.0.10 and a PIC18F2550 and a DS18B20 ( 10k Resistor see attached electric shema )
I change only the LCD -> RS232
The Result is:
21.48
21.54
21.48
21.42
21.48
21.48
21.48
21.48
perfect!
Your Flowchart makes the Dezi perfect for me ;-)
I will study your calculation.. ;-)
I have try this like you made with one wire icon
The DS18B20 is connected at my Experiment like this shema: ( 10 k Resistor ) ..
Next step i will try the Formula for Farenheit too. If you have the Formula for your Calculation i would be happy if you post it ;-) so i do not puzzle longer how this must go on ;-) ;-) ;-)
Best wishes
Rudi
hyperion007
Please try this one:
(8.65 KiB) Downloaded 880 times
Rudi
Post by Rudi »
Hi keejay,
i supply/added only Info to the DS18B20.
Normaly the DS18B20 is corect calibrated - this is for -10 .... + 85 °C with Tolerance that given by the Manufacturer.
This is the Temp Area for corect "Deviations" that is in the Appplication Note / Datasheet write (Tolerance)
But this mean not, if the "LCD shows 21,2 °C" that 21,2 °C is corect - you must compare with a Thermometer if you want to work with the temp value and if this must be right..
example:
My Ds18B20 works ,
the Thermometer shows ~ 19,4 °C
the DS18B20 gives 22,9 °C
So i subtract the Difference ( 3.5 ) from the get and make test.
this was not enough - so i make a substract of 4.3 then a substract of 4.5
Now, the value from DS18B20 agrees with the "eyes reading value " from Thermometer ca ...
Each DS18B20 works difference. My second has a Difference of ca. -1.3 so i make a 1.5 add to the Measurement result of the DS18B20.
One Tip
The measurement will be Difference if you make measurement very fast, because the Self-heating by the current consumption exist at/in the DS18B20 ( it must work faster ;-) ... remember to this..
My Delay is 5000 ms = 5 sec
I attached a picture.
This run at Pic 18F2550, without ( MPLAP ) and with the OneWire Icon ( FC ) same.
Best wishes!
Rudi
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi Rudi!
Would you share your last update with me. As you see: http://www.flowcode.co.uk/mmforums/viewt ... 54&t=15265
I also have make experiment with this device. :roll:
Thank´s in advance
Best regard
Jorgen
Rudi
Post by Rudi »
jgu1 wrote:Hi Rudi!
Hi Jorgen,
of course - I'll here tonight after work ( MEZ ca 19:30 ) as attachement. I will post both Mplap and Flowcode.
Edit: Jorgen, if will be late today at work ( trainings ..) , i will post it at weekend, I hope this is ok ;-)
Best wishes!
Rudi
Post by jgu1 »
Hi Rudi!
Of course. Look forward to test it. :D
Nice weekend
Jorgen
Rudi
Post by Rudi »
Hi Jorgen, hi guys,
attached is the mplap ( i use x version 1.85 ). later i attached the FC6 too - i will sort out for better reading -
you will have it here until monday morning :-)
Best wishes!
Rudi
ps: remove the .zip from file, ( MPLAP.DS18B20.7z.zip -> MPLAP.DS18B20.7z )
attachment as 7z is not allowed so i added simply the point and zip ( .zip )
EDIT: Attached is the FC OnWire Version now, too
keejay
Flowcode v5 User
Post by keejay »
Hi Rudi/hyperion,
Thanks for the posts. I have been away for a few days. I will try the various suggestions that you made and see what I can achieve. Will let you know. Maybe its just a timing issue or something like that.
Post by jgu1 »
Hi Rudi!
Thank's for sharing. Look forward to make a test. I dowload later today. :D
Thank you
Best regard
Jorgen
Today I ordered two of these:
(104.42 KiB) Downloaded 16225 times
At £1.99 for stainless steel waterproof version with free P&P not a bad price.
So i'm going to have a play with the temperature sensor as well.
Will post how I get on with it
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
They go for about £8 on some of the component websites, and that's for the plastic coated ones.
They look very good, and they don't have to come from China etc.
Hi John,
JohnCrow wrote:and they don't have to come from China etc.
The come from Singapore.
Since postage is free, they can't be making that much on them.
Had some spare time today, so I have created a flowchart to read the DS18B20 Temperature sensor (see above post) that arrived some time ago.
The the flowchart/hardware works with temperatures above and below 0C.
So if temperature is -3.2 for example, that should be displayed on the hardware.
Tested on a EB006 V9 programmer (16F1937 fitted), EB005 LCD.
resistor used is a 4K7 and is pulling data line up to +5V supply.
Accuracy is very good and temperature is displayed to 2 decimal places.
Here are features from the datasheet including range and accuracy:
(85.71 KiB) Downloaded 15947 times
Thanks Jac for mentioning accuracy :)
DS18B20 Thermometer V1a.fcfx
(10.79 KiB) Downloaded 900 times
Rudi
Post by Rudi »
hi martin
happy new year!
thanks for sharing!
i have two thing changed. my ds18b20 shows 2.7 °C to much. so i have add a variable for calibrate.
i found the formula that value of reading the ds18b20 allways 16 each 1°C so i make my variable for correction
2.7 x 16 = 43.2 , i make it without float so 43 was ok.
one problem i get, if meassuring value example xx.06 °C the zero is not show, only xx.6
i add a controll icon for temp2 and add then a Zero
i add two picture.
nice calculate " > 64000"
this is the best formula way i see for DS18B20 !
thanks to jac, too!
runs like clockwork and like a dream
best wishes!
rudi ;-)
Pactor
Has thanked: 20 times
Been thanked: 14 times
Post by Pactor »
Hello from a baffled man in need of a brain transplant
I was trying medelec35 DS18B20 Thermometer V1a program
I happen to have the arduino connected so I tried it on that and it's works perfectly temp readings perfect as far as I can tell.
But I then tried using the pic chip as in the program and all I get in minus readings, I've checked the clock freq settings it's getting data back but it's up in the 65000 area but the raw coming back on the arduino is down in the 100's I can't see where I'm going wrong,
Thanks for any help
Hi Pactor,
If you can post your flowchart, I can take a look at it for you.
Pactor
Post by Pactor »
Hello Thanks for the reply,
Well its your own flow chart I've changed nothing except selected the arduino UNO and changed the ports used all else is the same.
As I say it works perfectly on the Arduino temp readings returned perfect seem dead right.
But when I tried it on a PIC 887 I get readings miles out, down in the minus when it should be about 20.
Not sure where I'm going wrong.
I have ordered a slower crystal as the uno runs at 16Mz and I have the PIC at 20Mz
I try that first before I bother you too much
Thanks very much
Pactor wrote:But when I tried it on a PIC 887 I
That's why I wanted to see the flowchart.
You need to have altered configuration settings to make it work.
That could be the issue.
I always do a 1sec flasher test if any flowchart does not work on hardware.
Pactor
Post by Pactor »
Yes I did the LED flash and it seem to be 1 sec.
I've tried it on a PIC877 there's not many settings to change on that, I've set the freq and HS and disabled watchdog
I was wondering if it had to be used on a certain pin on a PIC mirco as the arduino has a Serial Data pin marked and it works perfectly on that.
At the moment the display reads -0.6 and the RAW is 65535
but run the same program on the UNO and its reading in the 20's.
I'm doing something stupid I'm sure of it.
I'll give it a rest for a while
Thanks very much
What clock speed are you clocking the PIC at? Could be the PIC is running too slowly to correctly achieve the strict 1-wire timings. An AVR with the same crystal frequency as a like for like PIC will run approx 4 times faster which might explain why the AVR/Arduino is managing to drive the 1-wire bus.
