DSPIC33FJ256GP710A error compiler
Wolfgang Kos
Has thanked: 2 times
Been thanked: 3 times
Post by Wolfgang Kos »
i will make a test programm for DSPIC33FJ256GP710A.
Now it comes this error Error:
Settings in '__FGS.sec' are not valid for target device 33FJ256GP710A
I deleted the code and the error like the same.
Show this:
___________________________________________________________________________________________________________________________________
Target folder: C:\EPC\1FLOWC~1\EXPLOR~1
Source name: C:\EPC\1 Flowcode\Explorer 16\dsPic33FJ.fcfx
Title:
Description:
Device: PIC16.33F.33FJ256GP710A
Generated by: Flowcode v6.1.2.0
Date: Monday, June 01, 2015 09:50:53
Users: 1
Registered to: Wolfgang Kos
Licence key: YJ9FDQ
http://www.flowcode.co.uk
Start des Compilers...
C:\Program Files (x86)\Flowcode 6\compilers\pic16\batchfiles\pic16_C30_comp.bat "dsPic33FJ" "C:\EPC\1FLOWC~1\EXPLOR~1\" "33FJ256GP710A"
Launching compiler...
C:\EPC\1FLOWC~1\EXPLOR~1>pic30-gcc -c -mcpu="33FJ256GP710A" -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\MX_support" -Wall -std=gnu99 "dsPic33FJ".c -o "dsPic33FJ".o
Compilation successful!
Completed compilation, return = 0
Start von Linker/Assembler...
C:\Program Files (x86)\Flowcode 6\compilers\pic16\batchfiles\pic16_C30_link.bat "C:\EPC\1FLOWC~1\EXPLOR~1\dsPic33FJ" 33FJ256GP710A 33F
C:\EPC\1FLOWC~1\EXPLOR~1>pic30-gcc -Wl,"C:\EPC\1FLOWC~1\EXPLOR~1\dsPic33FJ".o,-L"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\C_tools\lib",--heap=256,--report-mem,--script="C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\Support\33F\gld\p33FJ256GP710A.gld",-o"C:\EPC\1FLOWC~1\EXPLOR~1\dsPic33FJ".cof
c:\progra~2\flowco~1\compil~1\pic16\bin\bin\..\bin/pic30-coff-ld.exe: Error: Settings in '__FGS.sec' are not valid for target device 33FJ256GP710A
Error returned from [pic30-gcc.exe]
C:\Program Files (x86)\Flowcode 6\compilers\pic16\batchfiles\pic16_C30_link.bat Hat den Fehlercode 1 gemeldet
_________________________________________________________________________________________________________________________________________________________________________________________
Can anyone help, Thank you.
Wolfgang
Re: DSPIC33FJ256GP710A error compiler
Hello Wolfgang,
It seems to be a compiler error, there is another effected device reported here: http://www.flowcode.co.uk/mmforums/viewt ... sec#p52380
You could try removing the config from your program by unticking the config options. This should allow you to compile and then the options can be added into the hex file manually or using a tool like MPLAB.
Wolfgang Kos
Hello Benj,
thank you very much.
When I unticking the config option, I can compile... :D
