Rotary Encoder Text Input
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Afternoon All,
Trying to make a text input using a rotary encoder, cannot seam to get it to count correctly seams to only count down, and doesn't seam to count in 1's sometimes jumps 3 - 4 or is this a simulation thing ?
Re: Rotary Encoder Text Input
Hi Steve I believe for best results you either need to have the encoder check for change s within a port interrupt or you can take a look at this post and see if it helps
Steve001
Post by Steve001 »
cheers martin will have a go later
407charles
Has thanked: 41 times
Been thanked: 19 times
Post by 407charles »
Here are some examples of a quadrature encoder programming. There are different strategies for making a counter, that's what you need to do in order to write on a display. You will convert the numbers to characters by using the command print ASCII, from 22 which is the "space" character to 126 which will display the "~" character. You can set upper and lower points for the interval of characters needed. For example, from "0" to small case "z", you will set the intervals from 48 to 122. I tried the programs on a hardware after finish them and they work perfect, if you have a problem check your hardware. I also attached a small program for writing on a display but is set for arduino, you will need to set it for your controller, if you run it in the simulator only press the encoder once at a time, however, it work fine on the hardware. I hope this help. Best regards.
Writting Data.fcfx
(14.5 KiB) Downloaded 365 times
Rotary encoder III.fcfx
(11.83 KiB) Downloaded 389 times
Rotary encoder IV.fcfx
(14.93 KiB) Downloaded 399 times
Often encoders have a position the knob will settle in but this position is not spaced 1 single increment or decrement apart.
Usually there is 4 signal transitions in between each click position.
00
01
11
10
and then back to 00
So what I sometimes do is divide the count by 4 to get the actual position in terms of meaningful clicks.
Steve001
Post by Steve001 »
Thanks for the info guys will have a look into it later
Hi Steve, Just remembered about this post
