dspic30f2010
dspic30f2010
I need dspic30f2010 ic 4 pwm control. when i try to add not created hex file getting errors. please give me solution. and is it possible to attach build flowcode with 4 pwm
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Re: dspic30f2010
Hi and welcome to forums!
Could you attach your flowchart to the message so we can investigate better?
I tried to make 4 pwm work on FC V7, and found out the compiler doesnt like it for some reason...
EDIT:
Ill link a post here; V6 case might be same as the V7, so Flowcode does not currently support more than 2 PWM components at one time...
EDIT:
Ben wrote:It seems we currently only support the 2 x CCP type PWM on the dsPIC devices.
The other 3/6 PWM are advanced motor control PWM channels which may require a separate component to be created. With the 8-bit PICs I managed to include the advanced PWM using the standard PWM component but with the 30F2010 it looks like it will be tricky to do this.
Re: dspic30f2010
Hi sir,
I have try with depict30f4011 ic that is only 4 channel ccp if. That is supported to 4 pwm but that is very costly for sinewave inverter
