Is it possible to have the source API file to modify it and allow control of the extension ports on the AllCode and to be able to control them by an AppInventor android application?
Currently, we can only control the 4 servo motors.
Greetings
Bruno
PS: How to set the dashboard so that the replies to posts are sent directly to my email address?
File Source API
Re: File Source API
Hi Bruno,
What additional functionality are you requiring. Maybe we can add it to the API functionality for you.
Re: File Source API
Hello Benj,
Thank you for your help, I would like to pilot:
- 3 graphic displays: GLCD: uOLED-128-G2 : http://www.4dsystems.com.au/product/uOLED_128_G2/
I already found on the forum a modification of the file gLCD_EB075_4D.fcpx: viewtopic.php?f=7&t=18947&p=82103&hilit=goldelox#p82103
- 1 Stick 8 RGB LEDs "NeoPixels": RGB WS2812 : https://www.lextronic.fr/P29159-stick-8 ... ixels.html
A few years ago, I had already piloted the Formula robot with an EB024 bluetooth card, I would like to redo an API interface to have access to all the inputs / outputs of the AllCode in order to be able to work my students on both Flowcode7 and AppInventor.
Is it still possible to have the source file of the API in order to adapt it permanently to my needs?
Greetings
Bruno
Greetings
Bruno
