After a great deal of faffing around with code from V4 imported into V8 and not working I seem to have found the problem but how to fix it ??
I have attached the code. If you compile this and look at the .lst file you will see that no TIMER0 Overflow vector is generated and indeed no interrupt code generated either !!
If I run this through V4 these elements of the program are there and indeed the program works !
How can we fix this !!!
Iain
Interrupt Problem
iain wilkie
- Has thanked: 13 times
- Been thanked: 9 times
iain wilkie
Re: Interrupt Problem
Taking this problem forward. I have attached a program for ATTiny13 with simply an enabled Timer0 interrupt and the interrupt routine toggling an output line.
This simulates ok BUT will not run on hardware. When you look at the .lst file it produces you will see there is no timer overflow vector created and indeed no interrupt code !! hence the reason it doesnt work.
If this is replicated in V4 it is absolutely fine !
By the way I also note that no .asm file exists !!
This is driving me nuts ......
Iain
Iain
- Flowcode1 TEST.fcfx
- (7.94 KiB) Downloaded 255 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Thanks for spotting the bug.
Please try the attached updated file, to go into directory
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\AVR
Then reload your project
- ATTINY13.fcdx
- (6.31 KiB) Downloaded 244 times
iain wilkie
Bingo !!!!
All working great now, thanks for the fast update, can hopefully get on with my evaluation of Flowcode8 now
Cheers
Iain
Cheers
Iain
