String to num 1st Zero lost
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
I found some answer for question below
SteveM » Tue Jun 10, 2014
Loosing 1st zero during converstion of num to string
There's no way to do that directly, because the values are stored within the chip as fixed length binary numbers. e.g. if you store your number as a ULONG (4 bytes), it will always be 32bits long inside the chip. When you convert the String to an Integer, any leading zero's in the string will just be ignored, and the chip pads the number with enough 'binary zeros' to fill the bytes.
Steve suggested to get the length of the string, however this is OK during the (back) num-to-string conversion.
Question
How can I save to integer string "077" without loosing 1st Zero?
StringToNumZeroLost_1.fcfx
(11.58 KiB) Downloaded 211 times
Has thanked: 187 times
Been thanked: 205 times
Re: String to num 1st Zero lost
Just heading out, sorry to be brief.
What about using Right$ in a calculation?
e.g.
x$ = 123045
y$=Right$(x$,3)
y$ would equal 045
Just a thought and might not be applicable in your scenario.
Leading zeros can't be used for non-strings as they will be treated as octal i.e. to the base 8 rather than base 10
If you did enter a leading zero in an expression eg MyInt = 0123 then the actual value of MyInt will be decimal 83, which will not be what you are expecting.
The only way of displaying a leading zero is in a string format.
viktor_au
Post by viktor_au »
Sure... but I wanted the integer as 077.
Looks like I have to flag the converted integer 77 (from "077" string) as negative.
