Hello Martin,
Unfortunately, after testing the result is similar to the one obtained in the video that I sent you.
Multiple unreadable characters appear.
I have also tried the example of:
https://www.matrixtsl.com/wiki/index.ph ... :_Segment)
and the result is the same. There are even segments that do not light up.
F.
No funciona proyecto con pic16F883
- Has thanked: 70 times
- Been thanked: 440 times
Re: No funciona proyecto con pic16F883
Okay - so it's starting to sound more like a wiring / hardware issue? Except that you managed to get it to work from other languages?
I notice in the video that the display segments are very bright - do you have a current-limiting resistor to each digit?
I noticed with my 4 digit display that if I didn't pull the unused digit pin (d1 - pin 12) high (I left it floating) that digit 1 'mirrored' digit 3. Do you have correct values for 'low' (common cathode/anode) set correctly?
As a 'test' (whilst trying to work out the wiring) - I connected a pin to digit select (via a resistor) and another to the segment 'pins' in turn - to check which segments illuminated. When I had two 'digits' selected - I got two segments illuminated too... (Note I set one pin to 'high' and one 'low')
Elsewise - I'm running out of ideas....
The hardware has a resistance of 150 Ohms in each segment. Perhaps it is a little low and that is why the digits seem to shine a little.
With other languages it works perfectly, so I rule out that it is a hardware problem.
But I would like to pass the same project to Flowcode.
The same thing also happens to me that I don't know where to cover the problem to solve it, that's why the reason for the queries in this forum.
Could it be a problem with the compiler?
F.
F.
I doubt it's a problem with the compiler. The fact it all works from another compiler is odd though
What happens if you try to light a single segment - output 0 to a digit select pin and 1 to segment pin (using output icons or add single digital pins as properties and do select = 0, segment = 1 in a calculation block) - swap 0 and 1 if segment doesn't light....
