Add STM32F446ZCT6 ARM MCU in component library
karthickefy
- Has thanked: 4 times
- Been thanked: 9 times
Hi Matrix Team,
We need your help to add STM32F446ZCT6 MCU in the component library. It is quite urgent. We already have Flowcode 8 Pro License including STM ARM package license. We need to develop the firmware to test MCU's Internal ADC for one of our project. But Flowcode library doesn't have this STM32F446ZCT6 component. Please support. Thanks for your help in advance.
- component library.PNG (34.49 KiB) Viewed 7598 times
karthickefy
Re: Add STM32F446ZCT6 ARM MCU in component library
Thank LeighM,
It will be more helpful to us.
Karthick,
Karthick,
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Please try the attached FCD file, drop it into the following directory and restart Flowcode
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARM
We will get this into the auto update system later.
- 32F446ZC.fcdx
- (61.05 KiB) Downloaded 214 times
karthickefy
Thanks for your support LeighM. I will test and let you know the result later.
karthickefy
Hi LeighM,
Today I have start developing the code for analog channels with STM32F446ZCT6 and STM32F303VCT6 components and I found some mismatch in ADC pins in both STM MCU components. Can you please help to check and update it?
Below are the details:
As per datasheet STM32F303VCT6 MCU has 39 channel ADC. But Flowcode component has only 9 Ch ADC.
As per Datasheet STM32F446ZCT6 MCU has 24 Channels ADC. BUt Flowcode component has only 16 Ch ADC.
In our project, we used all the ADC AI pins in both Chip. So please help to resolve these issues. Thanks.
Below is the datasheet link.
https://www.st.com/resource/en/datashee ... f303vc.pdf
https://www.st.com/content/ccc/resource ... 141306.pdf
Karthick.
Karthick.
- STM32F446ZCT6 has very less AI pins.PNG (44.81 KiB) Viewed 7533 times
- STM32F303VCT6 very less ADC.PNG (45.06 KiB) Viewed 7533 times
karthickefy
Hi LeighM,
Thank you very much for your fast reply. Also, I need another help. How to communicate the ARM MCU's UART port component directly through FDTI TTL UART adaptor (without using MAX232 IC)? I have tried to communicate but FDTI receives wrong Data. If MCU sends string "1" computer received 0A in Hex. Please guide me on how to communicate the MCU directly without any inverter IC(MAX232).
In our product, there is no Max232 inverter IC circuit populated and our product FW directly communicates through UART (TTL) through FDTI chip. For testing the ADC value (I will develop the FW through Flowcode and communicate through FDTI), I need to use the same TTL method in our Functional Tester.
Thanks in advance.
Karthick
Thanks in advance.
Karthick
- test uart.fcfx
- (10.1 KiB) Downloaded 229 times
- uart.PNG (965.78 KiB) Viewed 7522 times
- LeighM
Could you move this latest post to a new topic?
We now have three issues in this thread and it could get confusing
It would also help other users when searching issues.
Thanks!
Thanks!
karthickefy
Hi LeighM,
Done. Thanks. Please help with these 2 topics.
Karthick.
Karthick.
- LeighM
Please try these ...
32F446ZC.fcdx
STARM_CAL_ADC.c
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM
32F446ZC.fcdx
STARM_CAL_ADC.c
- STARM_CAL_ADC.c
- (32.61 KiB) Downloaded 268 times
- 32F446ZC.fcdx
- (61.12 KiB) Downloaded 218 times
karthickefy
Hi LeighM,
Thanks. I downloaded .FCDX file into the specific folder and now I can see all the ADC pins for STM32F446ZCT6 part. I will check ADC tomorrow and update you the result.
Also I verified all STM32F446ZET6 and STM32F446 Nucleo discovery board (Which has STM32F446ZET6 Chip)component and these components also have the same ADC pin count issues. It will be good if you correct all.
Thanks for your support.
Karthick.
Karthick.
karthickefy
HI LeighM,
If you update the STM32F446ZET6 parts similar like STM32F446ZCT6, I can test it now in my home and update you on the result immediately.
I have STM32F446 Nucleo board on hand and I can test now. Please check.
Karthick.
Karthick.
- LeighM
Thanks, here is the 32F446ZE
- 32F446ZE.fcdx
- (61.69 KiB) Downloaded 193 times
karthickefy
HI LeighM,
Yes. ADC is working fine with STM32F446ZCT6 ARM MCU. I can read the ADC value through UART. You can modify the ADC for other MCU's. Thanks.
Karthick.
Karthick.
- ADC WORKING WITH STM32F466ZC.PNG (9.79 KiB) Viewed 7467 times
