ESP32 OLED display via SPI
AzaleaMB
Post by AzaleaMB »
Hello i was hoping someone could help me with connecting a ESP32 Wrover to an 1.5" 128 x 128 OLED just to display temps ect.
Im not sure if i need to use SPI Master or just use the SSD1351(SPI) component or both.
In the component properties of the gLCD_SSD1351_SPI1 which is what im thinking it need im not sure how to configure the connections and also it appears flowcode has a labeling issue on the reset connection as when you hover over it, it says Instruction/Command pin connections not "reset".
Could some one please help me with the code needed just to print a string to the OLED display
OLED 2.jpg (42.58 KiB) Viewed 8933 times
Re: ESP32 OLED display via SPI
Please can you post your program so far and I'll have a quick look for you.
Also thanks for the info regarding the tooltip on the reset pin.
AzaleaMB
Post by AzaleaMB »
Thank you for your reply,
Please see the attached program, its extremely basic as i just want to establish communication to the display at this stage.
oled test.fcfx
(10.01 KiB) Downloaded 251 times
Pins GPIO34 to 39 are input only and so are not capable of digital output. Can you reconnect the display to other Pins, e.g. on PORTA or PORTB 0 to 1.
AzaleaMB
Post by AzaleaMB »
Thank you I will try your suggestion and see if it works.
I appreciate your help.
AzaleaMB
Post by AzaleaMB »
Thank you very much.
That worked, I can now communicate with the display you help is very much appreciated thank you again.
:D
rexkit
Post by rexkit »
Hi guys, can anyone educate me on SPI 4 Wire & 8080 SPI for talking to OLED Displays?
I ordered 4 @ 256 x 64 OLED Displays ( Link Here ) from China, and asked for 4 Wire SPI as this is how the Tutorial i was following is configured, but the displays have arrived configured for 8080 Parallel, so i am trying to decide if i should re-solder the board, send them back (painful) or try to use them how they are configured.
I am using a ESP32 and the OLED controller is a SSD1322.
This is what i am working on copying:
https://www.youtube.com/watch?v=RnVeXkrrnPI
Im not educated enough to know if how the displays are configured at the moment is suitable for the project, if it is slower than 4 Wire SPI, etc.
Any advice would be greatly appreciated.
Learn to know how to identify asbestos in plaster walls and people at risk of developing asbestos-related diseases. How to check for asbestos.
