Sorry to disturb you, but I was wondering if you could take some time out to help me.
I am currently developing a system which will allow a user to automatically run a bath at a preset temperature and level. It will be used to reduce the risk of injury to OAPs, children and those with special needs.
I am using the matrix E-blocks components to build the main electronics for the system. I have an Atmel Mega32 microcontroller, which I will use to control 12v solenoid valves to run the the water.
What I am stuck on, is how to control the solenoids using Flowcode – what do I need to do in Flowcode to get the solenoids to switch on and off?
I realise I need to use a relay board and have managed to set the hardware itself up, however I can't seem to find the way to interact with the relay board within Flowcode
Due to the fact that I am the utter definition of a beginner to Flowcode, and have no background in C, it would be benefitial if any solution offered was as easy to follow as possible!
Thank you for your time and any help would be much appreciated!
Kind Regards,
Choppy
