I was using the EEPROM component and had some compiling errors, so I downloaded your sample read / write eeprom and got the same errors. Please see the compiler text below.
__________________________________________________________
File name: C:\ULGLC3QT\EEPROM%20Example[1].c
Generated by: Flowcode v3.2.2.40
Date: Thursday, March 06, 2008 18:01:52
Licence: Professional
Registered to: xxxxxxxxxxxxxxxx
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "EEPROM%20Example[1].c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
internal error: can't parse input file name 'EEPROM%20Example[1].c'
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" EEPROM%20Example[1].c -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F88 -la -c2 -o EEPROM%20Example[1].pp -v -d _BOOSTC -d _PIC16
runtime error R6002
- floating point not loaded
Error: preprocessing error
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
Any thoughts on the cause?
Thank you,
Ralph
Compile to HEX error
Re: Compile to HEX error
Hello Ralph
The length of the file name should not effect the compilation process.
However the square brackets in the file name would probably cause problems.
What is allowed and not in the filename?
I have had all sorts of file names and they are mostly OK although I thought there was a length limit. But recently its gone pear shaped when I copy a working file to a new filename almost the same and it says β€hex can not be found’
Filenames that work are:-
Test
Test1
2520V4 10bit3
2520V4 10bit2
But not:-
2520V4 10bit4
2520V4 10bit3a
2520V4 10bt3a
2520V410bit3a
2520V410bit3a
2520V410bit333
Some of those are no longer than ones that do work.
I am using the PICkit 2 programmer with your standards mods to Compiler Options
Test
Test1
2520V4 10bit3
2520V4 10bit2
But not:-
2520V4 10bit4
2520V4 10bit3a
2520V4 10bt3a
2520V410bit3a
2520V410bit3a
2520V410bit333
Do you have an answer to this? I guess it's more a PICkit problem than Flowcode so not fair to ask you.
Also do you prefer tagging questions onto very old similar posts or generating new ones?
Yes the filename problem you are having does indeed seem very strange. I wonder if it is because somewhere along the lines the Dos 8.3 filename is being used instead of the NTFS filename. eg 2520V4~1.hex this may explain why some work and other dont. Eg I dont know what happens if you have more then 9 file names that all start with the same characters.
2520V4~1.hex
2520V4~2.hex
2520V4~9.hex
For my money I prefare tagging older posts as it means less searching for related solutions etc. However this can be annoying when you just want to post a quick question so im happy with either method.
2520V4~1.hex
2520V4~2.hex
2520V4~9.hex
Have not fully resolved this, but as long as I use short names I have not yet experienced the error.
