I am working on a project where I try to have a selectable CAN bus rate. What I would like to do is to be able to read alternative values for the CNF1, CNF2 and CNF3 settings from EEPROM and send the values to the MCP2515 CAN controller.
The approach that I've been trying is this sequense.
Do a first standard Initiation of the CAN.
Read values from EEPROM
Set the CAN controller in configuration mode
Send the new CNF1, CNF2 and CNF3 values
End CAN controller configuration mode
So far I have tried to do custom C code for the CAN controller configuration and sending the values but I can't get it to work. It won't even compile.
Has anyone tried something like this and made it work?
Should I be using a different approach?
Ideas please.....
Selectable CAN bus rate
- Has thanked: 6 times
- Been thanked: 44 times
Re: Selectable CAN bus rate
I have used a similar technique to reprogram the CAN receive filters and interrupt enable flags in a MIAC (after allowing standard initialization).
The following code was used in a C code block.
// Request config mode.
FCD_CAN0_CAN_Config(REQOP_CONFIG);
//Initialise all the CAN device registers
//enable SPI
clear_bit(MX_CAN_CS_PORT, CAN_CHIPSEL);
FCD_CAN0_SPI_SendByte(CAN_WRITE); //CAN write mode
FCD_CAN0_SPI_SendByte(0x00); //Address of filter 0 0x00
//Reprogram the CAN comms Filters
FCD_CAN0_SPI_SendByte( FCV_MOD_REQ >> 8 ); // RXF0SIDH 0x00
FCD_CAN0_SPI_SendByte(FCV_MOD_REQ); // RXF0SIDL 0x01
//disable SPI
set_bit(MX_CAN_CS_PORT, CAN_CHIPSEL);
delay_us(10);
FCD_CAN0_SPI_SendByte(0x08); //Address of filter 2 0x08
FCD_CAN0_SPI_SendByte( FCV_MOD_INT >> 8 ); // RXF2SIDH 0x08
FCD_CAN0_SPI_SendByte(FCV_MOD_INT); // RXF2SIDL 0x09
//disable SPI
delay_us(10);
FCD_CAN0_SPI_SendByte(0x2b); // Address of CANINTE 0x2B
FCD_CAN0_SPI_SendByte(RX1IE);
//disable SPI
//Put the CAN device into normal mode
FCD_CAN0_CAN_Config(REQOP_NORMAL);
Direct calls from C code to component functions require addition of the prefixes added by Flowcode
E.g. CAN_Config() is renamed FCD_CAN0_CAN_Config() in the final program.
If the compilation is failing due to due to unresolved function calls, or undefined variables, reading the C file produced by Flowcode should allow you to see the required representation.
The CAN component includes a large number of register and flag definitions which can also be viewed in the C file or Custom code windows.
//enable SPI
//disable SPI
delay_us(10);
//disable SPI
delay_us(10);
//disable SPI
