I have down loaded a source file from microchip site for the RTCC pictail board that I have purchased. Is there a way to import this into flow code and add it as a macro or library function that I can call from flowcode and send to the controlling hardware.
Thanks,
Rick
importing C, hex code files into Flow Code 5
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: importing C, hex code files into Flow Code 5
You can't just put that into FC..you have to customize the code to adopt in Boostc..Most of your C code might be easily done by FC and rest you can add as C code..
Enamul
Enamul
