EB006 multiprogrammer
Tuhina Deep
Has thanked: 4 times
Post by Tuhina Deep »
Hi all,
I am facing problem with the multiprogrammer,i think that chip mounted on MCU multiprogrammer got damaged somehow. Can i replace it by local chip? or the original chip contain some program in it ? I need suggestion.Please help me out.
Thanks in advance
Tuhina Deep
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: EB006 multiprogrammer
Post by JohnCrow »
I assume you mean the device that is at the top of the board near Port E, rather than the PIC that is supplied with the board.
If your programmer is V6 or earlier, you will be able to get a new device from matrix, however from V7 with the device being surface mount, changing it is not an easy option.This chip contains the firmware that allows the programmmer to communicate with flowcode via PPP3, so a local sourced device wont have the firmware in it.
Im sure the guys at marix will post an answer as to how to get the device, when the open on Monday.
Tuhina Deep
Thank you Sir
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Hello Tuhina,
Please PM me with an email address and ill give instructions on how you can obtain a PPP firmware chip.
