servo pwm input
serstel
Been thanked: 1 time
servo pwm input
Post by serstel »
Can the pic receive pwm from a source that normally drives a servo, like an RC Gyro? Is there a way that, something like this, can be done?
Yes the PIC can receive the PWM signal as long as its frequency is not too high. The easiest way to monitor it would be to start the tmr0 running
tmr0 = 0;
Then wait until the pulse goes high.
while (porta & 0x01 == 1);
Once it goes high you would collect the value in the tmr0 register
FCV_MYVAR = tmr0;
Then restart the timer
tmr0 = 0;
and monitor how long the pulse was low using the same method.
serstel
Post by serstel »
Thanks for the tip, however if I were to use the pic to drive servos as well, then I would need the tmr0 register to provide the interupts neccesary to produce a PWM output for the servos.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
On a lot of chips (e.f. 16F87x and 16F88x series), the PWM is generated by the Timer2 source, which means that Timer0 would be free.
