LCD not working on my project Hardware
- JLeith
- Has thanked: 146 times
- Been thanked: 26 times
Hello All
Just before I lose it I need a fresh look at what is happening to my LCD display
I loaded my PIC with another program and the LCD worked.
Only Difference it used Port C pins
The Program that won' display is using Port D
The program runs in Flowcode.
I cant see why PORT 5 won't work in the Hardware state.
Hope someone can load the Flowcode and has a LCD to try.
Don't need any inputs the LCD show read 'MOSQUITO" on power up.
PIN A7 should be LOW for 'Mosquito" and High for "Pee Wee"
Attatched is The LCD drawing and Flowcode
The only think left is to rewrite my program with only a LCD output and see if that works.
But I will hold that thought encase someone can see what I have missed.
John
John
- LCD wirking
- Pitch Count Master LCD.jpg (56.75 KiB) Viewed 13449 times
- JLeith
Re: LCD not working on my project Hardware
Opps I missed the Oscillator was not on Internal
Here is a New FLowcode. Still not working
John
John
- Pitcher count Master.fcfx
- (96.86 KiB) Downloaded 360 times
Hi John,
You have still got an issue with your configuration settings and possibly osccon setting as well!
If you enter F0 in a calculator that converts to binary it will show: As you can see from the data sheet if checking what 11110000 does to osccon:
from MSB
1 = Enable PLL no mater whether is enabled or not = 4x osc frequency.
1110 = 8Mhz (4x8 = 32MHz)
0 = unimplemented
00 = allow osc selection from configuration settings = set for internal osc
So unless you set clock frequency to 32MHz or change osccon value LCD will not work as all the timings will be out by
(32-19.6) /32 x 100 = 38% error.
Too much for the LCD to work!
So with current osccon value of 0xF0 you must set clock speed to 32MHz for LCD and your project to work.
Also MCLR is enabled so have you got a resistor going from MCLR to +5V?
from MSB
0 = unimplemented
- JLeith
Martin thank you for your knowledge.
I tried to follw the design we worked on with The Servo and displays.
I readjusted the timing from 8Meg to 32Meg and it is running.
Now my next hurdle is the LCD I had in my parts box turns out to be a parallel LCD not a Serial like we used in the Servo design
The Serial uses 4 Data and the Parallel needs 8 Data ?
I did place an order for 2 new Serial LCD.
Martin is there a way to add a Parallel LCD to Flowcode ? Just a thought if I had these 2 LCD's
John
John
- JLeith
I have the Serial LCD working
What I did was Disable my SPI ( Wireless programming )
I don't know how the code messed up my LCD. It like it was frozen.
Martin are you familure with the SPI interface.
Here is my Flowcode with the SPI actions disabled
Martin could you look over my SPI code ?
John
John
- (97.14 KiB) Downloaded 321 times
Hi John,
Sorry not had any dealings with SPI LCD
So will not be able to assist with that.
- Has thanked: 20 times
- Been thanked: 52 times
Hi John,
Should your first disabled SPI macro be "Initialize" rather than "Uninitialize"? What SPI device are you sending data to?
Grant in Winnipeg
Grant in Winnipeg
- JLeith
Hello Grant,
Yes the SPI macro is off line at the moment. I had issues with the LCD and it turned out that the LCD is a 8 BIT and I have 4 BIT.
I thought my program was crashing but it was the LCD.
I hope to get back to SPI this weekend.
I plan on using wireless TX / RX ( NFR905 )
First thing I'm going to try is connecting the PIC's via Hardwire to ensure they communicate. I'm not 100% sure on how to collect the info at the slave side.
Here is a picture of my thoughts for TX.
Grant have you worked with Wireless Transmission ?
- PIC to NFR905 1 way.jpg (47.53 KiB) Viewed 13336 times
- NRF905.jpg (28.68 KiB) Viewed 13336 times
No I have not had a chance to play with it yet. Have used SPI though. Just wanted to clarify what the SPI device was and find the datasheet:
http://www.nordicsemi.com/eng/content/d ... 5_v1.5.pdf Haven't looked closely at your FC or the datasheet yet but I had issues with the SPI clock phase description...having to select the opposite of what I thought I needed according to the datasheet. Although I don't think that would cause a lockup, just prevent receipt of the data.
- JLeith
Hi Grant
I have printed off the PDF ealier 80 sum pages. Staples copy cantre helped.
My NFR905 are sceduled to be here around April 5th then I can give it a try.
I enjoy FC projects it keeps my retired brain sharp.
Sometimes it slips. Missed the clock speed.
I'm trying to find 16X2 (4 bit) LCD for a reasonable price. Here in Vancouver they run about $30 each. I did buy a couple on Ebay for $7 but they don't have any left.
On the comment "You have used SPI" did you do it via wirless or direct ?
Off to build the PCB.
John
John
Hi John,
From my student days I used to buy from here and they have a good selection of LCDs available which should work in the 4-bit mode.
http://www.futurlec.com/LCDDisp.shtml
- JLeith
Thank you Benj for the link
Here is what I think is the 4 Bit.
Benj in the world of LCD is it the Controller ( HD44780 or other) that converts 4 bits to 8 bits internal
John
John
- LCD16X2BL.jpg (42.19 KiB) Viewed 13297 times
No wireless. The datasheet link was for my own(and others') reference.
I have been using LCDs from China, with or without the I2C adapters. FC has a prebuilt I2C LCD component that works nicely with the 1602 I2C adapters.
Free shipping(be prepared to wait 1 month). No taxes or duties if the total value is under $20 CAD.(seems to be the case even when the actual value is not).
http://www.dx.com/p/lson-fm1602c-lcd-module-301616
http://www.dx.com/p/lcd1602-adapter-boa ... rds-216865
http://www.dx.com/p/funduino-iic-i2c-16 ... red-173588
- JLeith
Hi Grant
Thank you for the link
Yes the Month is terrible from China and they say they are shipping by Air Mail. Guess slow planes.
I did order my NFR905 wireless form DX. DX is in China and they say I should be expecting in 22 days but 30 is the norm.
So when you did your SPI it was via wire from MISO to MOSI with clock ?
John
John
Hi John,
We use the 4-bit mode by default in Flowcode but the "LCD (Generic)" component available from the search category allows the 8-bit data mode. The 8-bit mode can be useful for faster display operations at the cost of 4 extra I/O pins.
Yep the LCD needs 8-bit commands but supports 2 x 4-bit operation to clock in the 8-bit command. From the HD44780 datasheet.Benj in the world of LCD is it the Controller ( HD44780 or other) that converts 4 bits to 8 bits internal
https://www.google.co.uk/url?sa=t&rct=j ... yQ&cad=rjaThe HD44780U can send data in either two 4-bit operations or one 8-bit operation, thus allowing interfacing with 4- or 8-bit MPUs.
- JLeith
Thank you Beji
I'm using the PIC16F1937 ( 40 Pins )
With a Quad 7 segment ( 12 PINS )
6 switch inputs (6 PINS)
SPI ( 3 PINS )
PWR/GRD ( 4 PIns )
Down to 1 Spare pin
Benj in the Speech Output is there a link to hear what the 'Phoneme Selection" sounds like ?
John
SPI ( 3 PINS )
PWR/GRD ( 4 PIns )
Down to 1 Spare pin
John
Hi John,
If you download the speech example from here then it should simulate on your PC when you hit play and show you what it sounds like.
http://www.matrixtsl.com/wiki/index.php ... de5f9b41a8
It's not amazing but it does work. Think 90's style talking watches or 80's style talking robots.
I should have the Phoneme sequences for all the numbers somewhere 0-9 and then ten, twenty etc. I'll have a dig and see if I can find them.
Found it, a talking volt meter
Actually working very well converted to v6 and running in the simulation. Just hit play and press the switch on the panel to take a reading.
I've added this to the Wiki now too as it's a great working example. My work PC stutters a bit between Phonemes but this is not there on the hardware.
- JLeith
Odd
I have a new laptop and for some reason it sounds like a "ROBOT" that needs new batteries ?
Maybe I just need a tone the audio is ruff.
Benj what format is the phoneme ?
If I recall back in FC 5 was there not a more 'English" audio ?
John
John
- JLeith
Where do I get this Speech pattern ?
I was google searching to learn more on 'Phoneme" and found this Flowcode 6 page.
And it has a Flowcode 6 example ( Speech 2 )
John
John
- Speech2.fcfx
- (9.48 KiB) Downloaded 263 times
Yep that sounds about right. You can change the pitch property to alter the sound a bit.I have a new laptop and for some reason it sounds like a "ROBOT" that needs new batteries ?
The phoneme's are in simple unsigned byte format we simply queue them up in a audio buffer and then stream them out using a DAC or PWM.Benj what format is the phoneme ?
Flowcode v5 used the exact same Phoneme data in the speech component but did not simulate at all.If I recall back in FC 5 was there not a more 'English" audio ?
Speech 2 uses the Real Speak speech engine via the simulation. This sounds much better and you can use sentences rather then breaking words down into phonemes but please note this is simulation only.And it has a Flowcode 6 example ( Speech 2 )
If you needed this type of speech for an embedded application then you could record the audio from the simulation as a WAV file and then play the audio back from say an SD card using the FAT component.
- JLeith
Excellent information Benj
Thank you.
I played around with the sounds and even in the hardware I had a very small spaeker and it was not clear enough.
I have decided to use a Buzzer for 10 msec.
I really appreciate the wisdom of yourself and others.
John
Thank you.
John
