'MARKER' problem with Flowkit V2
beanie
Has thanked: 1 time
Been thanked: 6 times
Post by beanie »
I wonderwed if anyone knew how to get the code to compile for ICD with the new flowkit, I've attached a screen grab of the error I recieve.
Cheers
Matt
(41.09 KiB) Downloaded 850 times
(104.41 KiB) Downloaded 850 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: 'MARKER' problem with Flowkit V2
Post by LeighM »
Hi Matt
Would it be possible for you to attach your project file (.fcfx)?
Or send it PM?
beanie
Has thanked: 1 time
Post by beanie »
PMed
cheers
LeighM
Post by LeighM »
Thanks for the file.
This is a problem with the BoostC software call stack.
To get around the problem you can switch off the BoostC software stack by removing the directive from the linker parameters in the compiler options.
Build->Compiler Options...
"Linker/Assembler" tab
Parameters:
remove the following from the end of the parameter string
    -swcs 6 2
Save as a new setting (with a new name e.g. HWCS) and tick the "Default compiler ..." box to allow the new settings to be active.
Here is similar thread on the topic ...
http://www.matrixtsl.com/mmforums/viewt ... ck+#p67772
